    Delimiter Settings (Ctrl + Double Click) to include more brackets
    2 Posts 2 Posters 1.6k Views 1 Watching
    • ijoel92I Offline
      ijoel92
      Hi all,
      First post here! And quite noob with customizing notepad++. I’m open to guidance!
      I’ve just found the very useful option to select inside parentheses holding Ctrl + Double Click. But it only accepts one starting character and one ending character.
      These parenthesis can be modified for other characters in Settings -> Preferences -> Delimiter.
      I think it would be useful if we could use multiple brackets i.e. [{()}] and even single and double quotes (if we like). It will be useful for many languages.
      How can we add this functionality? I can’t seem to find anything related, if there is another post, please point me in the other direction. If not, how would we go and change this?
      PS: I don’t know if this should be in this same thread but along with this double click feature, it would be useful to extend/shrink this selection with keyboard shortcuts like shown in this link https://ihatetomatoes.net/vscode-tips-select-everything-between-brackets-quotes/ (smart selection in VSCode)
      astrosofistaA 1 Reply Last reply Reply Quote 0
      • astrosofistaA Offline
        astrosofista @ijoel92
        Hi @ijoel92
        Not natively. But there is a Python script that I think does what you want.
        See details in this and subsequent posts.
        If you want to try the script, here are some instructions to install it:
        Have fun!
