    HyperText
    4 Posts 2 Posters 820 Views 1 Watching
    • WhiskyDripW Offline
      WhiskyDrip
      Hello All
      As a newbie .
      Is there a HyperText Language Patch ?
      If so where would I find it ?
      Thanks
      WD
        Alan Kilborn @WhiskyDrip
        @WhiskyDrip said in HyperText:
        I guess you’d have to first explain what such a thing is…
        WhiskyDripW 1 Reply Last reply Reply Quote 0
          WhiskyDrip @Alan Kilborn
          Oh , yeah sorry.
          What type of Language should I select to code in a .htaccess file ?
          To get Highlighting etc.
          It’s the Config file for my site on my Providers Server (UNIX).
          Thanks.
          WD
            WhiskyDrip
            Hello.
            Problem solved. Thanks to @carypt over on > < https://github.com/notepad-plus-plus/notepad-plus-plus >
            Link here for the User Defined Language.
            https://github.com/notepad-plus-plus/userDefinedLanguages/blob/master/udl-list.md
            WD
