    How can I select text from different parts of a document.
    2 Posts 2 Posters 607 Views 1 Watching
    • Michael Haigh 0M Offline
      Michael Haigh 0
      I have a large file with over 3 million words. I have it in date order and want to select all parts that relate to certain subjects in the file. I have tagged every piece of information with (*1) (*2) etc. There are anything up to 300 entries for (*1) throughout the text. How can I grab every piece relating to (*1) and concentrate in one place?
        Hello, @michael-haigh-0 and All,
        Just two constraints :
        • Your (*###) tags must begin the line OR are preceded with blank space chars only. But these tags may be followed with some text
        • You must run, at least, the v7.9.1 N++ release or a later one
        If so, the road map is :
        • Open your file in N++
        • Open the Mark dialog ( Ctrl + M )
        • SEARCH (?s)^\h*\(\*1\).+?(?=\(\*\d+\)|\z)
        • Tick the Purge for each search option
        • Tick the Wrap around option
        • Leave all other options unticked
        • Click on the Copy Marked Text
        • Close the Mark dialog ( Esc )
        • Open a new tab ( Ctrl + N )
        • Paste the clipboard’s contents ( Ctrl + V )
        => Each (*1) section is natively separated with a blank line and a ---- line ;-)
        Now, just get concentrated !
        Of course, change the 1 of the regex by any number required !
        P.S. :
        You may, as well :
        • Tick the Bookmark line option, in the Mark dialog, before clicking on the Mark All button
        • Go back to the very beginning of your file ( Ctrl + Home )
        • And, simply, browse through each Bookmarked line, with the F2 or Shift + F2 shortcuts !
