    Hi. Can someoane help me? I want to find a text and to bold it with regular expresion. Please help, I need it for work. Thanks
    2 Posts 2 Posters 488 Views 1 Watching
    • Alexandru TanasaA Offline
      Alexandru Tanasa
        Hello, @alexandru-tanasa and All,
        • Which kind of text or literal text needs to be bold ?
        • Which file type are you using ( For instance, a Markdown file with extension md )
        • How you presently obtain the change of ‘some_text’ into ‘some_text’ ?
        Note : You can use the </> option to write raw text, in your next post !
