    Match < and > and what's between it
    12 Posts 3 Posters 3.7k Views 1 Watching
    • glossarG Offline
      glossar
      Hi all,
      I expect this regex to match < and > and what’s between it but it won’t for the following example: <.*?>>
      [m2][b]1.[/b]<jemand rechnet mit etwas[i]([c darkred]Dat.[/c])[/i]>[/m]
      In the file, the only fixed anchors are numbers followed by a dot, which together surrounded by respective [b] and [/b] (kind of html tags) and “[/m]” at the end of a line (just before CR LF). Between < and >, there may or may not be characters like [, ], (,), and betwen these (like in the example above), dots, or other relevant ones which might be part of regex language, hence are to escaped, etc.
      I want it to match anything between < and > (the characters < and > included) (so that I could group that part), keeping the said numbers and said [/m]'s intact and in place.
      Find: [b](\d+.)[/b](<(.*?)>>)
      Replace with: [b]$1[/b] [c darkslategray][b]<$2>[/b][/c][/m]
      So, basically I just want to put a “[c darkslategray][b]” before every < and a “[/b][/c][/m]” after every >, which meets thr above condition(s).
      Thanks in advance!
      glossar
      glossarG Alan KilbornA 2 Replies Last reply Reply Quote 0
      • glossarG Offline
        glossar @glossar
        Addendum:
        … hence are to escaped (or maybe to be included until reaching the >). I can’t find the right wording, I hope you get the idea.
          Hi, glossar and All,
          Your regex cannot work because it searches the shortest range of standard chars between a < char and the string >> !
          So, I suppose that the following regex S/R should do the trick, without the need of any group :
          SEARCH <.+?>
          REPLACE [c darkslategray][b]$0[/b][/c][/m]
          So, from the text :
          we get :
          [m2][b]1.[/b][c darkslategray][b]<jemand rechnet mit etwas[i]([c darkred]Dat.[/c])[/i]>[/b][/c][/m][/m]
          Now, I was intrigued by the two successive [/m] at the end of the replacement !
          If I try to identify the starting tags and the appropriate ending tags, in the resulting replacement string, it gives :
          Obviously, the last [/m] is orphan and should not occur !
          So, I think that the right S/R is, rather :
          SEARCH <.+?>
          Note that, in replacement, the $0 syntax represents the overall match, i.e. the <..........> area !
            Alan Kilborn @glossar
            @glossar said in Match < and > and what's between it:
            So in general, I’m confused as to why OP would think that <.*?>> would match this:
            …at all, because there is no occurrence of >> in the data!?
            This would be a really basic error, one that I’d think someone could figure out before creating a posting here.
            glossarG 1 Reply Last reply Reply Quote 2
            • glossarG Offline
              glossar @Alan Kilborn
              @guy038
              Thank you for the effort, I appreciate it!
              You were a bit late with your help :P, so I went with poor-man’s-way in the end: replaced < with # and > with ~ :)) and put them later back. I’m glad it worked. :)
              While we are on it, what’s difference between an “+” and “asterisk” in the context of <.*|+?>? And also difference between “$1” and “$0”? I know all regex rules and co. are all there, but maybe you would shortly and simply put it?
              Anyway, thank you again.
              My bad! An \ was supposed to be before “>>” - at least that’s how it stays in my notes: “<.*?>> : Match < and > and what’s between it”
              Alan KilbornA glossarG 2 Replies Last reply Reply Quote 0
                No problem, but you see the problem yet?: You’re not using “black boxes” here to express your regex and thus this site is consuming some of your characters, so it is hard for anyone reading to know what you really mean. As you’re composing a post here, type your critical data, then select it, then use the </> button in the “toolbar”. Then it will do
                this
                to your text, and it (mostly) will leave it alone.
                • glossarG Offline
                  glossar @glossar
                  Just noticed that the \ before >> won’t show here.
                  • glossarG Offline
                    Ah, okay, indeed I did and do need that </> trick! Thanks.
                      @glossar
                      You can also do it like this when composing (blown up and captured as an image):
                      which will still prevent the site from stealing your intent, but will show it in a less-harsh manner:
                      test
                        Hello @glossar,
                        Look at this text :
                                            So, < this is a test > which continues with <this other part>, so TWO CONSECUTIVE '<.........>' areas in a SAME line
                         Regex  (?-s)<.+?>      |................|                      |...............|                      |.........|   ( +? is a LAZY   quantifier )
                         Regex  (?-s)<.+>       |........................................................................................|   ( +  is a GREEDY quantifier )
                        As you can see :
                        • The regex (?-s)<.+?> matches the shortest range of standard characters, all different from >, till a first > char
                        • The regex (?-s)<.+> matches the greatest range of standard characters, till the last > char of current line
                        Now, to surround any individual <.......> area with, let’s say, #- and -#, you have two possibilities :
                        • Just use the $0 syntax, in replacement, representing the overall match
                          • SEARCH (?-s)<.+?>
                          • REPLACE #-$0-#
                        • Defines a group with parentheses, whose contents are rewritten as \1, $1 or ${1}, in the replacement regex :
                          • SEARCH (?-s)(<.+?>)
                          • REPLACE #-\1-#    OR    #-$1-#    OR    #-${1}-#
                        Now, note that you could have found all this information, on NET, in tutorials on regular expressions ! For instance, with the regular-expressions.info site :
                        • https://www.regular-expressions.info/repeat.html    ( Greediness vs Laziness )
                        • https://www.regular-expressions.info/refreplacebackref.html    Choose Boost in the first drop-down list    ( $0 vs $1 )
                        and so on … ! Thus, I’m not going to “re-invent the wheel”, in each reply !
                        So, I advice you to read this FAQ and, then, please, RTFM ;-)) Just note that this abbreviation can also be used in the plural !
                        Best Regards
                        BTW, @glossar, did my assumption, about an excess [/m] ending tag, was exact ?
                          Alan Kilborn @guy038
                          @guy038 said in Match < and > and what's between it:
                          Nice reference. We should direct questioners here with some “regularity”!
                          It took me a moment to realize what the second dropdown is for!
                          It appears to be so you can compare two things! Am I right about it?
                            Hi, @alan-kilborn and All,
                            Yes, these two drop-down lists help us to compare if a specific functionality is supported or not, between two regex engine flavours, as well as some specificities for each one !
                            Note that my last sentence, between parentheses ( $0 vs $1 ) is not connected at all, with these two drop-down lists, but, simply, refers to subjects asked by @glossar !
                            BR
