    regex: Parsing html tags in other tags / links and titles
    32 Posts 3 Posters 6.8k Views 1 Watching
    • Robin CruiseR Offline
      Robin Cruise
      File1.html
      <ul id="myNavigation">
          <li><a href="https://my-website.com/page-1.html" title="Page 1">Page 1 (34)</a></li>
          <li><a href="https://my-website.com/page-2.html" title="Page 2">Page 2 (29)</a></li>
          <li><a href="https://my-website.com/page-3.html" title="Page-3">Page 3 (11)</a></li>
      </ul>
      File2.html
      <div class="categories-name">
         <a href="https://my-website.com/page-66.html" title="Page 66">
         <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page 66 <span>27</span> </p>
        </a>
      </div>
         <a href="https://my-website.com/page-67.html" title="Page 67">
         <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page 67 <span>24</span> </p>
         </a>
      </div>
         <a href="https://my-website.com/page-68.html" title="Page 68">
         <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page 68 <span>07</span> </p>
         </a>
      </div>
      @guy038 @Alan-Kilborn
      Thank you. Please understand that finding this solution, was not easy.
      First, I knew that @guy038 is one of the best REGEX developer on earth. He already gave a solution, in another post, to a PARSING html. so I thought he would succeed.
      Second, in another post, someone else gave a solution with PowerShell, of another problem. I remember also that post.
      So, I knew that this problem can be resolve, but I had to try both options.
      Now, maybe will be a better way to handle regex and files, by integrate notepad++ them into another program such as PowerShell.
        Hi, @robin-cruise,
        But, could you provide, also, the result.html file ?
        Thanks
        BR
        Robin CruiseR 1 Reply Last reply Reply Quote 0
          Robin Cruise
          @Alan-Kilborn said in regex: Parsing html tags in other tags / links and titles:
          but this is really off-topic for a Notepad++ forum
          No, sir. Is an opportunity to understand that a problem has many solution, even if people told you that isn’t possible.
          By the way, the same problem can be done in LINUX, much easier…with bash script, but that’s another story.
            Robin Cruise @guy038
            @guy038 result.html is just a blank file, put in the same folder with File1.html and File2.html
            After you run the code in PowerShell, the output result will appear into result.html
            please test the PowerShell code. You will see in result.html the structure html from the File2.html but with the values extracted from File1.html
              Hi, @robin-cruise,
              OK but could you provide the result.html file AFTER running the Powershell script !
              BR
              Sorry, with my old XP SP3 machine is a bit out of date !
                Robin Cruise
                @guy038 this is the result.html after run the PowerShell code
                  Robin Cruise
                  the single problem in PowerShell is that not every regex formulas that works in notepad++ works there. Seems that PowerShell don’t like \K or \G or replacement such as (?2\2)
                    Hello, @robin-cruise, @alan-kilborn and All,
                    OMG, now I understand the all story ! In fact, you’re did not express your needs correctly, in your first post ! The File-2.tml is useless and we just can go from the result_1.hmtl file to the result.html file !
                    </ul>
                    MUST BECOME:
                      </a>
                    </div>
                       </a>
                    </div>
                       </a>
                    </div>
                    can something like this be done with regex?
                    But… you SHOULD have written :
                    </ul>
                    MUST BECOME
                       <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page 1 <span>34</span> </p>
                      </a>
                    </div>
                       <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page 2 <span>29</span> </p>
                       </a>
                    </div>
                       <p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i> Page-3 <span>11</span> </p>
                       </a>
                    </div>
                    And yes, this transformation can, indeed, be solved with ONE regex S/R only !!!
                    What misled me was the fact that your output file contained other values than the ones indicated in the initial file ! ( Page 66 <span>27</span>, Page 67 <span>24</span>, Page 68 <span>07</span>... which are completely out of scope :-(( I vainly looked for a link between, for example, the strings "Page 1">Page 1 (34) and Page 66 <span>27</span> !
                    So, Robin, now, it’s fairly easy to get the right regex S/R !
                    From this initial text
                    </ul>
                    with the following regex S/R :
                    SEARCH (?-i)^\h*<li><a href="https://my\-website.com/(.+?)" title="(.+?)">.+?\((.+?)\)</a></li>|<(ul id="myNavigation"|/ul)>\R
                    REPLACE ?4:<div class="categories-name">\r\n\x20\x20\x20<a href="https://my-website.com/\1" title="\2">\r\n\x20\x20\x20<p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i>\x20\2\x20<span>\3</span> </p>\r\n\x20\x20\x20</a>\r\n</div>
                    we do get the expected text, totally identical to your result.html contents ! Moreover, you do not need the Powershell script any more !
                       </a>
                    </div>
                       </a>
                    </div>
                       </a>
                    </div>
                    Et voilà !
                    Notes :
                    • The groups used are :
                      • Group 1 : the part after website.com/ till the double quote, not included
                      • Group 2 : the title part
                      • Group 3 : the string between parentheses, before </a>
                      • Group 4 : either the literal string <ul id="myNavigation"> or the literal string </ul>, which must be deleted, in replacement
                    • Ths regex string \x20\x20\x20 occurs three times, in the replacement regex, and correspond to the needed leading spaces in each <div ......</div> section. Changed it as desired !
                    P.S. :
                    And, if you want to change the lines <li>.........</li>, ONLY inside the <ul...............</ul> sections, use this second regex S/R, derived of the generic regex S/R, discussed in other topics :
                    SEARCH (?s-i)(?:<ul id="myNavigation">|(?!\A)\G)(?:(?!</ul>).)*?\K^\h*<li><a href="https://my\-website.com/(.+?)" title="(.+?)">.+?\((.+?)\)</a></li>
                    REPLACE <div class="categories-name">\r\n\x20\x20\x20<a href="https://my-website.com/\1" title="\2">\r\n\x20\x20\x20<p class="font-16 color-grey text-capitalize"><i class="fa fa-angle-right font-14 color-blue mr-1"></i>\x20\2\x20<span>\3</span> </p>\r\n\x20\x20\x20</a>\r\n</div>
                    Now, end the job, getting rid of the literal string <ul id="myNavigation"> and the literal string </ul>, with, simply :
                    SEARCH (?-i)<(ul id="myNavigation"|/ul)>\R
                    REPLACE Leave EMPTY
                    We need consecutive regexes S/R because the values <ul id="myNavigation"> and </ul> are used as anchors, in the first generic S/R and must not be deleted during the first regex process !
                      Alan Kilborn @guy038
                      @guy038
                      Hi Guy… it is too funny.
                      Now, before solving a problem, you have to solve another problem: What the problem actually is!
                      It’s good that you have the talent and perseverance to do that; well, it’s good for the OP I suppose.
                        Robin Cruise
                        @guy038 thank you, I knew that you can do it. I believe, you are the best regex developer in the entire word.
                        I understood one thing. Never say “it can’t be done” and even if it can’t be done in one way, you can always find another way. Be open to another programs.
                        Much more important: if you give someone a new perspective, that someone will be able to see clearly the problem and to find the solution much easy.
                        So, my friends. Thanks a lot, from now on I know that many people understood also the power of PowerShell, and it can be used very often to modify files by integrate regex.
                          Hi, @robin-cruise and All,
                          I would say definitively not the best !
                          For instance, just think of this man here and here.
                          Jan Goyvaerts :
                          • Created the fantastic regular-expression.info site and still maintains it !
                          • Developed all these valuable regex tools : PowerGREP, RegexBuddy, RegexMagic and EditPad Pro
                          This is just an example of the many developers, involved in regular expressions !
                          BR
                            Robin Cruise
                            of course there are others, but only @guy038 helped me and all notepad++ community with so hard to find solutions.
                            and I am using notepad++ and grepWin (and as for the Batch Process I using a great tool named TextCrawler)
