    I need help
    2 Posts 2 Posters 443 Views 1 Watching
    • yasin koohestaniY Offline
      yasin koohestani
      Create a page that allows the user to view images. This page contains 5 thumbnail images, and 2 pull-down menus (to select the page background colour and the page text colour) and an area to display a larger image and associated description of that image. When the user selects a thumbnail image, the corresponding large image and the description of that image should display in the defined location on the form. You must use either the mouseover event listener or radio buttons with the getRadioValue() function shown in class to select the thumbnail.
        Ekopalypse @yasin koohestani
        @yasin-koohestani
        Same advice as before.
