    Bookmark sets of lines that does not meet criteria
    21 Posts 5 Posters 8.5k Views 2 Watching
      Hello @alan-kilborn and All,
      I’ve found out a simple example of the advantage of the conditional feature !
      Let’s suppose that you have a particular tag <guy> and that you want :
      • To delete the starting tag <guy> with, both, its leading and trailing space chars
      • To delete the ending tag </guy> with its leading space char, only
      • The simple and obvious solution is :
        • SEARCH \x20<guy>\x20|\x20</guy>
        • REPLACE Leave EMPTY
      • Now, this shorter regex S/R, with a conditional expression, related to group 1, is :
        • SEARCH \x20<(/)?guy>(?(1)|\x20)
      I verified that the suppression of 500,000 starting tags and 500,000 ending tags, in one step, take the same time, whatever the regex syntax used !
