    Notepad++ using a lof of CPU
    33 Posts 18 Posters 20.2k Views 7 Watching
    • lukas venuti coelhoL Offline
      lukas venuti coelho
      Hi guys, how are you?
      I had no problems wich the portable version of notepad++, I’m using it that way as it was impacting my machine resources.
      I had the same problem installing the application, I tested several versions, it could be a BUG with Win10 too.
      • Claudio NevesC Offline
        Claudio Neves
        Hello!
        My Notepad++ version 8.1.5 (32-bit) was constantly using 20-30% of CPU, even without doing anything on it, and just small files opened.
        I’ve uninstalled it, installed version 8.1.8 (64-bit), and the high CPU usage continued. Disabled all plugins renaming the plugins directory, and issue persisted.
        Debug Info:
        Notepad++ v8.1.8 (64-bit)
        Build time : Oct 19 2021 - 17:02:51
        Command Line :
        Cloud Config : OFF
        OS Version : 2009
        OS Build : 19043.1288
        Current ANSI codepage : 1252
        Plugins : none
        I have only around 8-10 files, all with less than 1MB. I really don’t have any idea of what could be causing this high CPU usage.
        I’m available to make whatever tests that may help finding what’s causing this high CPU usage .
        Thanks,
        Claudio Neves
        • artie-finkelsteinA Offline
          artie-finkelstein
          testing (ordered by increasing effort):
          • install the portable version instead (in a separate location)
          • install the portable x86 (32 bit) version instead (in a separate location)
          • cold reboot the computer (power cycle) and exit as many other applications as possible before starting the portable Notepad++ version
          • cold reboot the computer (power cycle) and run NO other applications before starting the portable Notepad++ version
          Note: One or more of the above may not be possible in a corporate environment
          FWIW: approximate commonalities-
          • Windows 10
          • 64 bit version of Notepad++
          • Zoom (the application) has seemed problematic, but that may just be me suspecting the whiteboard function
          Disclosure: I don’t use any of the above (Win 10, 64 bit Notepad++ or Zoom); I’m condensing observations in this and other threads
          • ArkadiuszMichalskiA ArkadiuszMichalski referenced this topic on
          • Andre ViolA Offline
            Andre Viol
            Same problem here.
            Debug info:
            Notepad++ v8.1.9.3 (64-bit)
            Build time : Dec 6 2021 - 19:21:37
            Command Line :
            Cloud Config : OFF
            OS Version : 2009
            OS Build : 19044.1415
            Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
            No recent history.
            Even with no plug-ins, same problem.
            Same situation as mvlaza described: if I open a menu, CPU usage becomes normal (very low)
            CPU usage around 30%
            Zenburn theme but with default theme same problem
            • Eduardo SchusterE Offline
              Eduardo Schuster
              Same Problem,
              No Docs open, no history check, CPU always in 25% or more.
              Command Line :
              Admin mode : ON
              Cloud Config : OFF
              OS Version : 2009
              OS Build : 19042.1415
              Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll NppExport.dll
                Ekopalypse @Eduardo Schuster
                @eduardo-schuster
                DSpellCheck.dll is not a standard plugin, could it be that this is
                an artefact from an old installation that is causing problems?
                • Aguilar DiasA Offline
                  Aguilar Dias
                  Same problem:
                  Notepad++ v8.3.2 (64-bit)
                  Build time : Feb 27 2022 - 03:35:46
                  Command Line :
                  Cloud Config : OFF
                  OS Version : 2009
                  OS Build : 19044.1526
                  I’d tried all other options: Portable, 32-bit
                  But after a few minutes using it, the cpu reaches more than 20% of CPU
                  • Alexandre LorenzattiA Offline
                    I’ve realized I have had the same problem since 2022/03.
                    Curious thing or not, I have a AMD Ryzen 5 3500U processor. I’ve made some tests and realized that after firing up Notepad++, it’s always CPU 2 that goes to 100% consumption which makes turn on the fan (see picture below).
                    Follows debug info:
                    Notepad++ v8.3.3 (64-bit)
                    Build time : Mar 13 2022 - 17:20:02
                    Command Line :
                    Cloud Config : OFF
                    OS Name : Windows 10 Home Single Language (64-bit)
                    OS Version : 2009
                    OS Build : 19044.1586
                    • Alessandro FazendaA Offline
                      Alessandro Fazenda
                      Same problem here, Notepad++ keeps using CPU when not focused/minimized. No plugins, fresh install.
                      I noticed most people here are using pt-br version of Windows. Can this be a languegue related issue?
                      Notepad++ v8.4.4 (64-bit)
                      Build time : Jul 15 2022 - 17:54:42
                      Command Line :
                      Cloud Config : OFF
                      OS Version : 21H1
                      OS Build : 19043.1826
                      Plugins : none
                        xomx @Alessandro Fazenda
                        @Alessandro-Fazenda
                        I have already tried to identify the culprit, but forgot to link here the corresponding N++ GitHub issue.
                        The good news is that for all the users who participated in the above issue, the problem solved miraculously itself at the end. But this also means that I could not finish my bug-chase.
                        What I think for now - it is not caused by N++ but either by Windows itself or by an AV. It is probably caused by a specific preinstalled hook (one user got hold of a usable callstack…).
                        • Alex LinsA Offline
                          Alex Lins @blacksnc
                          @blacksnc
                          Work for me! Thanks!
                            Andre Viol
                            The bug still persists for me. Using latest version.
                              PeterJones @Andre Viol
                              @Andre-Viol ,
                              @xomx linked to the official issue months ago. We in the Forum can do nothing to get bugs fixed – we can help users through the process of proving it’s a bug, and can sometimes find workarounds. But in the end, the official issues pages, like the one linked above, are where the official debugging occurs. If you want to remind the developers to continue working on the problem, there is the appropriate place.
                              In the discussion in that issue report, you will find links to debug versions, and requests for logs from that debug version. If it hasn’t been fixed yet, then you need to follow the instructions in that discussion, and post the results in that discussion, and hopefully @xomx will be able to take the information you provide there and help incorporate it into a fix.
                              Discussion Locked
                              This issue can only be fixed if people who have this problem participate in the official issue report at https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11556 . Posting in this Forum discussion thread will not propagate the information to all the right individuals. Any further discussion on this problem needs to occur in the official issue. As a result, this discussion is being locked, to encourage you to use the issue tracker to discuss the known issue.
                              • PeterJonesP PeterJones locked this topic on
                              • xomxX xomx referenced this topic on
