    Possible bug or setting missing
    10 Posts 5 Posters 1.4k Views 4 Watching
    • Geoff TaylorG Offline
      Geoff Taylor
      have upgrade from 7.9.2 to 8.1.1
      under SAVEAS in 7.9.2 you have normal text file (*txt ) it show the extension of the files
      under SAVEAS in 8.1.1 you have normal text file NO extension are Show how
      Is this a bug or is it a setting that as been turn off in error ?
        Alan Kilborn @Geoff Taylor
        @Geoff-Taylor
        Hard to understand you, but maybe you just need to experiment with this setting, right on the SaveAs dialog?:
        Geoff TaylorG 1 Reply Last reply Reply Quote 0
          And BTW, why is my SaveAs box light-colored when I have N++ in “dark mode”?:
            PeterJones @Alan Kilborn
            @Alan-Kilborn said in Possible bug or setting missing:
            Because those dialogs are controlled by the OS, and they think it’s too hard to color any dialog but Find/Replace/Mark.
            Alan KilbornA mere-humanM 2 Replies Last reply Reply Quote 0
              Alan Kilborn @PeterJones
              @PeterJones said in Possible bug or setting missing:
              Ah, okay, if I truly had my Windows in dark mode, and wasn’t just futzing around with N++ in its own dark mode, my open/save dialogs would also be dark. I get it.
              Am I the only one that thinks N++ dark mode is “meh”?
              artie-finkelsteinA 1 Reply Last reply Reply Quote 2
              • mere-humanM Offline
                mere-human @PeterJones
                Right. When you set Dark color in Settings > Personalize > Colors the dialog will be dark.
                • artie-finkelsteinA Offline
                  artie-finkelstein @Alan Kilborn
                  No, you’re not alone in that thought. I guess sometimes the developers feel they have to keep the clamoring masses appeased.
                    Geoff Taylor @Alan Kilborn
                    thanks for info
                    find that the File name Extentsions was not tick in the file explorer was turn off
                    After turn the File name Extentsions back on in the file explorer the file Extentsions in Notepad++ return
                      PeterJones @Geoff Taylor
                      @Geoff-Taylor said in Possible bug or setting missing:
                      Correct. Notepad++ uses Windows dialog boxes for the Open and Save As dialogs, and those follow the Windows Explorer setting for “Hide Extensions for Known File Types”. But note, this is nothing new between v7.9.2 and v8.1.1 – this has been true for the entire history of Notepad++.
                      Geoff TaylorG 1 Reply Last reply Reply Quote 1
                        Geoff Taylor @PeterJones
                        thanks for the info
