    Need help with custom syntax highlighting for a simple example, struggling to understand how.
    syntax highlight
    2 Posts 2 Posters 587 Views 1 Watching
    • stmavS Offline
      stmav
      Text file will look like this, each chat message appears on its own line:
      [2021/07/18 18:57] Mango: Hi how are you apricot?
      [2021/07/18 18:58] Apricot (meow123): Doing well thank you mango
      [2021/07/18 18:59] Apple (fruitfruit123): Hi guys how are you?
      How do I customize so I can have 3 different colors based on the syntaxing above? Basically I want:
      • The timestamp to be a light grey color
      • The username to be red, meaning “Mango” and “Apricot (meow123)” are usernames
      • The text messages (everything after the : in the username) to be black?
      Bonus points if it’s possible to insert spacing between the username and the chat messages!
        Ekopalypse @stmav
        @stmav
        Sorry, but this is hardly possible with the built-in UDL since parts
        are dynamic and UDL does not provide regex terms to identify different parts.
        You have to write your own lexer for this case.
        A scripting plugin like PythonScript can be used to make this possible.
        If you are familiar with another programming language there may be ways to use it as well.
