    I need help (or a programming manual) to develop a plugin
    developingdevhelperplugin
    5 Posts 3 Posters 1.3k Views 2 Watching
    • Walter Di BiaseW Offline
      Walter Di Biase
      I want to create a plugin that hides lines based on a string (for example all lines that contains “meta”), but I really don’t know how to to that.
      Basically I need to use many functions already included in Npp, but automating certain behaviors.
      Anyone could help me? Thanks in advance.
        PeterJones @Walter Di Biase
        @Walter-Di-Biase
        • https://npp-user-manual.org/docs/plugins/ => provides basic outline of a plugin, and links to template(s)
        • https://npp-user-manual.org/docs/plugin-communication/ => describes the messaging and notification systems, which is how a plugin gets access to any of the standard commands that Notepad++ accepts
        Walter Di BiaseW 1 Reply Last reply Reply Quote 1
          Walter Di Biase @PeterJones
          Thanks @PeterJones, but I cannot found how to hide lines, and that’s one of the npp functions that I want to use in my plugin.
          Basically I try to highlight some words (based on some criteria) and hiding lines. It’s for analizing a particular kind of log.
          Alan KilbornA 2 Replies Last reply Reply Quote 0
            Alan Kilborn @Walter Di Biase
            @Walter-Di-Biase said in I need help (or a programming manual) to develop a plugin:
            You would use this Scintilla function:
            https://www.scintilla.org/ScintillaDoc.html#SCI_HIDELINES
              @Walter-Di-Biase
              One thing to be aware of, though, with hiding lines: When you switch the active tab in Notepad++, Notepad++ itself will restore any lines you previously had hidden. So, if you want them to remain hidden (probably), you’ll have to capture the “buffer activated” event and then re-hide based on your saving of what was hidden before. Sounds a bit complicated? Yes, it is.
