    Window close button (X) does not register mouse pointer consistently when window is maximized on second monitor
    5 Posts 3 Posters 1.2k Views 1 Watching
    • neraiN Offline
      nerai
      I’ve been troubled by what looks like a bug for years and hope you can help me.
      I am on Windows 10, currently using Notepad++ 8.1.4. I have two monitors. The editor is maximized at all times (entire screen).
      On the primary monitor, which is located logically to the right, the close button of the window bar (“X”) works as expected. Every pixel of it is registered by the editor and leads to closing the window.
      On the secondary monitor, which is located logically to the left, this is not the case. When moving the mouse along the outer edge of the X button, it sporadically does not register. This effect changes anytime the mouse is moved, not when it is static. When clicking the button when not registered by the editor, the button indeed does not close the editor. Instead, it transparently goes through to the unrelated window of another program behind it, and (naturally) closing that window. As you can certainly imagine, this had some bad consequences for me.
      This effect applies to the minimize/maximize buttons of the window bar, too. I’ve screen recorded the problem to illustrate below. Please note that I am pushing the mouse up during all movement, and the mouse pointer never leaves the topmost edge of the screen.
      https://imgur.com/a/IwpwHU2
      There is no difference in behavior between maximizing the window manually (using the maximize button of the window bar) or dragging the window to the top of the monitor and letting it snap. I’ve compared this with a range of other programs (e.g. Explorer and cmd.exe). None of them showed this behavior.
      In any case, this has been going on for several years. I’m not sure how to report this as a bug, if my system is fubar, or what can be done to mitigate. I’d be grateful for any help or assistance.
      • Alan KilbornA Online
        Alan Kilborn @nerai
        @nerai said in Window close button (X) does not register mouse pointer consistently when window is maximized on second monitor:
        You don’t have to.
        It has been reported many times already.
        • neraiN Offline
          nerai
          Thank you @Alan-Kilborn
          I googled earlier, but only now have found this issue in the tracker (for reference: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8660 )
          Using this, I was able to fix the issue by setting “DPI awareness” to “Application”. This also fixed blurry font issues that I so far had ignored.
            Alan Kilborn @nerai
            What does this mean?
            Maybe if you elaborate about it, it could help other users.
            • Keith KeplerK Offline
              Keith Kepler
              Basically you need to modify the startup behavior of Notepad++ via Windows Compatibility tab.
              You can get here many ways, I’m just using task manager since I had notepad++ open.
              1. Start notepad++
              2. CTRL+ALT+DEL - open task manager.
              3. find notepad++ and right click on it and select --> Properties.
              4. Click the Compatibility tab
              5. Click Change High DPI Settings
              6. Check “override high DPI scaling behavior” and set it to Application
