    Replacement does not abide Regular Expression
    5 Posts 2 Posters 894 Views 1 Watching
    • CsyeCokTheSollyC Offline
      CsyeCokTheSolly
      So I was doing some things on notepad++ and I was trying to replace with Regular Expression but finds out it doesn’t abide by it’s options. Is there anything else I can do to replace with newline?
        Alan Kilborn @CsyeCokTheSolly
        @csyecokthesolly
        You’ve told the software that you want a . in your find expression to possibly match a newline character – and that’s exactly what it is doing for you.
        It is hard to tell what you really want, but perhaps you want to do your search in Normal Search mode?
        CsyeCokTheSollyC 1 Reply Last reply Reply Quote 1
          CsyeCokTheSolly @Alan Kilborn
          @alan-kilborn I’m trying to replace multiple lines with a replacement with multiple new lines.
            @csyecokthesolly said in Replacement does not abide Regular Expression:
            OK, well then you can use Regular expression mode.
            You can use a \R in the Find what box to match a line-ending character when you search.
            In the Replace with box, you have to use, for Windows, \r\n when you want to insert a line-ending.
              @alan-kilborn Thanks. That problem doesn’t occur now.
