    Practical to remove "white" areas between marked data on adjacent lines?
    7 Posts 3 Posters 1.2k Views 2 Watching
      Is it practical to remove “white” areas between marked data on adjacent lines?
      Example: I’d like the red coloring to “flow together” without a white gap, line-to-line in the following:
      I’ve experimented with Scintilla’s SCI_SETEXTRAASCENT and SCI_SETEXTRADESCENT, but they don’t seem to be the right things for this desire…
      Nick BrownN dailD 3 Replies Last reply Reply Quote 0
      • Nick BrownN Offline
        Nick Brown @Alan Kilborn
        @alan-kilborn
        Are you using markers or indicators?
        Nick BrownN 1 Reply Last reply Reply Quote 0
          Nick Brown @Nick Brown
          @nick-brown
          Sorry must be indicators, I just looked again.
          • dailD Offline
            dail @Alan Kilborn
            @alan-kilborn
            I’d recommend setting the indicator type to INDIC_FULLBOX and also adjusting the outline alpha to match the current alpha for the foreground.
              Alan Kilborn @Nick Brown
              @nick-brown said in Practical to remove "white" areas between marked data on adjacent lines?:
              Yes, I’m not doing anything special to achieve it, just Mark of test as provided by N++'s Find dialog Mark operation.
                @alan-kilborn
                Have you seen SCI_INDICSETSTYLE, and use INDIC_FULLBOX
                https://www.scintilla.org/ScintillaDoc.html#SCI_INDICSETSTYLE
                  Alan Kilborn @dail
                  @dail nailed it, and @Nick-Brown was very close (but slightly incomplete). Thanks, both of you.
                  If I do this in PythonScript:
                  editor.indicSetStyle(31, 16)
                  editor.indicSetOutlineAlpha(31, editor.indicGetAlpha(31))
                  Then I get the effect I’m after:
                  Note that 31 is the indicator number for red-marking, and 16 is the value for INDIC_FULLBOX.
