    Stuck in [Administrator] mode - My solution
    1 Posts 1 Posters 550 Views 1 Watching
    • MrToMM Offline
      MrToM
      Notepad++ v8.1.9.3 (32-bit)
      Build time : Dec 6 2021 - 19:16:45
      Command Line :
      Admin mode : ON
      Cloud Config : OFF
      OS Version : 2009
      OS Build : 19044.1415
      I appreciate this is an older problem but I’ve just [after a long time trying] solved this for myself and thought I’d post it in case it’s useful to anyone else.
      I tried running Notepad++ in ‘compatibility’ mode for Win 7. At some point in the process I was prompted to ‘test the application’ and report back once I’d done so.
      Above this message was a two line list of ‘things’ that windows was going to change in order to run the test…and one of them was ‘User Account Control - Run as Administrator’.
      I cancelled everything and opened up the UAC…and there’s the problem…
      I did as it said, clicked OK and restarted the PC.
      Notepad++ is no longer in Admin mode!
      I have no idea why the UAC was in this condition, it’s obviously been like it for some time.
      Happy New Year!
