    Print white words on white paper ?...
    5 Posts 3 Posters 1.0k Views 2 Watching
    • Elodie CEMOIE Offline
      Elodie CEMOI
      I use N++ for all my Arduino projects, and I set the language to C++, because it perfectly fits the Arduino syntax (.ino programs).
      The problem is that it is perfect as long as I work on the program, but some words are in white (on the black background of N++): when I print the program, the paper is (of course) white and these words cannot be seen !
      Any idea for a quick fix ?
      EkopalypseE PeterJonesP 2 Replies Last reply Reply Quote 0
        Ekopalypse @Elodie CEMOI
        @elodie-cemoi
        Have you played with the print options in the settings.
        Especially with the colour options?
          PeterJones @Elodie CEMOI
          @elodie-cemoi ,
          @Ekopalypse is right. Even though you didn’t say so, I am betting you are in Dark Mode, or at least are using one of the darker themes (light text on dark background).
          Settings > Preferences > Print > Colour Options controls how colors are handled during printing: as the user manual describes, the option No background colour behaves as you describe – using the foreground color (white/light-grey) for text, but not using the background color when printing (to avoid printing a black background). You probably want to pick black-on-white for printing… though that won’t print any of your syntax highlighting. If you want to print with syntax highlighting, I suggest (at least when you print), selecting a light theme in Settings > Style Configurator > Select Theme.
            Elodie CEMOI
            Thank you all: I have solved my problem by going to:
            Settings -> Print and select “invert” in the available options.
            This transforms the with text in black text: just what I needed.
            As you said, I am in Dark mode, but I didn’t want to change it: this “invert” option seems to work fine ,
            Thanks again,
              @elodie-cemoi said in Print white words on white paper ?...:
              You could just change it temporarily for printing (Default Theme, Print, Default Dark Theme). But Invert will work … though the inverted colors aren’t always the best for readability on printer paper / printer ink. But it really depends on what you like, which is why Notepad++ provides such flexibility.
