    Debug info dialog, what does Current ANSI codepage mean?
    8 Posts 6 Posters 2.5k Views 2 Watching
    • Bas de ReuverB Offline
      Bas de Reuver
      In Notepad++ in the menu under ? -> Debug info... -> Copy debug info into clipboard, what does the line with “Current ANSI codepage” mean?
      As far as I can tell it’s not related to the current file, so is it a general environment or Windows setting? Is it possible to change this setting somehow?
      The reason I ask is that someone reported that my CSV Lint plugin crashes on a certain file with diacritic characters in it, for example noël. I have the file but can’t reproduce the error but I do have the Debug info.
      The only noticable difference is Current ANSI codepage : 65001 on the pc where it crashes, and Current ANSI codepage : 1252 where the plugin doesn’t crash.
      So on this machine it crashes on a certain file
      Notepad++ v8.2.1 (64-bit)
      Build time : Jan 19 2022 - 18:43:05
      Command Line :
      Admin mode : ON
      Cloud Config : OFF
      OS Name : Windows 11 (64-bit)
      OS Version : 2009
      OS Build : 22000.493
      Plugins : CSVLint.dll mimeTools.dll NppConverter.dll NppExport.dll
      And on this machine the plugin works correctly:
      Command Line :
      Cloud Config : OFF
      OS Version : 2009
      Alan KilbornA PeterJonesP Lycan ThropeL 4 Replies Last reply Reply Quote 0
      • Alan KilbornA Online
        Alan Kilborn @Bas de Reuver
        @bas-de-reuver said in Debug info dialog, what does Current ANSI codepage mean?:
        I haven’t tracked it back in the N++ source, but would assume it leads to this:
        https://docs.microsoft.com/en-us/windows/win32/api/winnls/nf-winnls-getacp
        65001
        That seems like UTF-8.
        Michael VincentM 1 Reply Last reply Reply Quote 4
        • Michael VincentM Offline
          Michael Vincent @Alan Kilborn
          @alan-kilborn said in Debug info dialog, what does Current ANSI codepage mean?:
          @Bas-de-Reuver
          that appears to be correct.
          Cheers.
            For Notepad++, it means that, when a file is opened with ANSI as the encoding, see status bar:
            that the codepage indicated in the Debug Info will be used to determine the meaning/display of characters above byte-value 127.
            It must be, but I don’t have expertise because I’ve never had to do it.
            Obviously in your situation there’s a need…because you want to debug the problem you are seeing.
            It would be interesting if you come back here and post your efforts as you work on and hopefully solve your problem.
              PeterJones @Bas de Reuver
              @bas-de-reuver
              The top two answers (for me) for https://www.google.com/search?q=windows+10+how+to+change+default+codepage show two different ways of doing it. The one at SU is one I had seen before, but has caveats in some of the responses to that “solution”; I have never tried the one on the other site, nor seen any comments as to its effectiveness.
              • https://knowledgebase.progress.com/articles/Article/4677
              • https://superuser.com/questions/269818/change-default-code-page-of-windows-console-to-utf-8
              If you find practical results from either of those methods, it would be good to share them here.
                Hello, @bas-de-reuver, @peterjones, @alan-kilborn, @michael-vincent and All,
                @bas-de-reuver :
                Globally, I would say that the ANSI codepage ( or ACP ) is the default encoding used by all the Non-Unicode programs of your machines(s)
                To know which is the exact Windows encoding, hidden behind the ACP acronym, simply ask the registry :
                reg query HKLM\SYSTEM\CurrentControlSet\Control\Nls\CodePage /v *CP /t reg_SZ
                On my recent French Win 10 laptop, I get :
                HKEY_LOCAL_MACHINE\SYSTEM\currentControlSet\Control\Nls\CodePage
                    ACP    REG_SZ    1252
                    OEMCP    REG_SZ    850
                    MACCP    REG_SZ    10000
                Fin de la recherche : 3 correspondance(s) trouvée(s).
                This means that my system :
                • Uses the Win-1252 encoding when saving files with the ANSI encoding ( Single-byte character encoding of the Latin alphabet in Western languages )
                • Uses the OEM-850 encoding which is used when opening a console prompt window ( Single-byte character encoding of the Latin alphabet used under DOS in Western Europe )
                Moreover, Windows defines the MACCP - 10000 encoding, called MAC OS Roman ( APPLE Single-byte character encoding of the Latin alphabet in Western Languages )
                Instead of using the parameters of the reg program, you may simply filter the results of the CodePage key with the findstr built-in DOS command :
                reg query HKLM\SYSTEM\CurrentControlSet\Control\Nls\CodePage | findstr CP.*REG_SZ
                You’ll obtain the same displaying :
                    ACP    REG_SZ    1252
                    OEMCP    REG_SZ    850
                    MACCP    REG_SZ    10000
                For instance, a polish user could see :
                    ACP    REG_SZ    1250
                    OEMCP    REG_SZ    852
                    MACCP    REG_SZ    10029
                because :
                • Windows-1250 is a single byte encoding to represent Central or Eastern European languages, that use the Latin script
                • OEM-852 is a single byte encoding, used under DOS to write Central European languages, that use the Latin script
                • 10029 is an APPLE single-byte encoding, called Mac OS Central European to represent text in Central or Southeastern European languages, that use the Latin script
                • Lycan ThropeL Offline
                  Lycan Thrope @Bas de Reuver
                  @bas-de-reuver ,
                  Everybody has given you good answers, but as always, a good search will get you better depth answers. Goes way back, as guy alludes to. Here is the Wikipedia Link that can give you more information and links to other references.
                    Hi, All,
                    Forgot to mention that I got the main information from this link :
                    https://stackoverflow.com/questions/53691278/how-to-see-which-ansi-code-page-is-used-in-windows
                    BR
                    • Bas de ReuverB Bas de Reuver referenced this topic on
