    regexp help: lookahead and lookbehind with spaces
    12 Posts 4 Posters 1.8k Views 2 Watching
    • P Offline
      patrickdrd
      hello everyone,
      I would like your help with a regexp,
      I want to join 2 regexp in 1, i.e.:
      (f1|mls|ucl)\s*fantasy|fantasy\s*(f1|mls|ucl)
      in one statement (both ways),
      I mean I would like my regexp to match
      “f1 fantasy” (space in between, without quotes) and “fantasy f1”
      but not “f1 asasdasda fantasy”
      this is a generic regexp question,
      also how do I do lookahead and lookbehind in npp,
      thanks
        Alan Kilborn @patrickdrd
        @patrickdrd
        (?:(f1)|(fantasy)) (?(1)(?2)|(?1))
        Decribed in the N++ user manual.
        P 1 Reply Last reply Reply Quote 3
        • P Offline
          patrickdrd @Alan Kilborn
          @alan-kilborn thanks but I would like f1fantasy matched as well
            @patrickdrd said in regexp help: lookahead and lookbehind with spaces:
            Hmm, the target moves…
            I think you can figure out how to change my regex do that, given your first guess at it. :-)
            P 1 Reply Last reply Reply Quote 2
            • P Offline
              @alan-kilborn \s* is the 0 or more spaces but I can’t figure out where to attach it to, I tried all places and it doesn’t work
              I also got a couple more conditions to check for like mls and ucl
              P 1 Reply Last reply Reply Quote 0
              • P Offline
                patrickdrd @patrickdrd
                ok got it,
                (?:(f1|ucl|mls)|(fantasy))\s*(?(1)(?2)|(?1))
                  Hello, @patrickdrd, @alan-kilborn and All,
                  Actually, two solutions are possibles :
                  Regex A : SEARCH (?-i:(f1|ucl|mls)|(fantasy))\s*(?(1)(?2)|(?1))
                  Regex B : SEARCH (?-i:(f1|ucl|mls)|(fantasy))\x20*(?(1)(?2)|(?1))
                  It does not match exactly the same occurrences !
                  • Paste the text below in a new tab :
                  f1fantasy
                  f1 fantasy
                  f1      fantasy
                  uclfantasy
                  ucl fantasy
                  ucl            fantasy
                  mlsfantasy
                  mls fantasy
                  mls    fantasy
                  fantasyf1
                  fantasy f1
                  fantasy                f1
                  fantasyucl
                  fantasy ucl
                  fantasy          ucl
                  fantasymls
                  fantasy mls
                  fantasy                       mls
                  Match with \x{000D}\x{000A} (CRLF) in between :
                  f1
                  fantasy
                  Match with \x{000A} (LF) in between :
                  f1
                  fantasy
                  Match with \x{000D} (CR) in between :
                  f1
                  fantasy
                  Match with \x{0009} (TABULATION) in between :
                  fantasy	f1
                  Match with \x{0011} ( VERTICAL TABULATION ) in between :
                  f1fantasy
                  Match with \x{0085} ( NO-BREAK SPACE ) in between :
                  fantasy f1
                  with a Multi-lignes MIX of these SPECIFIC chars in between :
                  fantasy
                  		            f1
                  • Open the Mark dialog ( Ctrl + M )
                  • Tick only the Purge for each search and Wrap around options
                  As you can see, the regex A, in addition to match usual space chars, also matches a lot a “SPACE” characters !
                  => After the line of equal signs, some matches, possibly multi lines, occurred !
                  So the regex B, more rigorous, just matches zero or more \x20 chars ;-))
                  => The part, after the equal signs is not detected at all !
                  If your different words may be present in any case, simply replace the -i in-line modifier, within the non-capturing group, by the i modifier !
                  Best regards,
                  • P Offline
                    patrickdrd @guy038
                    @guy038 I prefere the first approach,
                    because I want it to match tabs as well,
                    also \n shouldn’t be a problem because I’m matching single line items
                    Neil SchipperN 1 Reply Last reply Reply Quote 1
                    • Neil SchipperN Offline
                      Neil Schipper @patrickdrd
                      @patrickdrd and @guy038,
                      In much the same way that Goldilocks found Papa Bear’s bed too hard, and Mama Bear’s bed too soft, but Baby Bear’s bed just right …
                      in the present context, surely \s is too promiscuous, and \x20 is too brittle, while \h is just right!
                      P 1 Reply Last reply Reply Quote 4
                        Hi, @patrickdrd, @alan-kilborn, @neil-schipper and All,
                        @neil-schipper is perfectly right ! This third solution (?-i:(f1|ucl|mls)|(fantasy))\h*(?(1)(?2)|(?1)) is just what you need as \h* will match any combination, possibly null, of Space, Tabulation and/or No-Break Space char(s) !
                        BR
                        • P Offline
                          patrickdrd @Neil Schipper
                          @neil-schipper I still tend to think that \s is slightly better because why not match “accidental” carriage returns/ line feeds?
                          which is higher? the possibility of an “accidental” carriage return/ line feed or a “next line mismatch”?
                          I don’t know if you understand, but I think the first is higher
                          Neil SchipperN 1 Reply Last reply Reply Quote 2
                            I don’t know enough about your data or the intended purpose of the pair matching to say either way, but I will say that, since you are gathering up either ab or ba pairs, then, a small error can make every subsequent pair a different pair from what would have matched without the error.
                            It’s up to you to think through whether this harms what you’re trying to accomplish, and if it does, to try to devise a strategy that could detect a malformed pair, and maybe skip it and then resync and pick up all subsequent pairs with desired grouping.
