    turkish characters problem
    6 Posts 2 Posters 3.0k Views 2 Watching
    • Ogün KovanO Offline
      Ogün Kovan
      i can only see turkish characters with encoding>character set>turkish>iso 8859-9 or windows-1254. but notepad doesnt save my decision and it gets reset every time i close it. i want one of those default not utf-8.
      i have never had this before. what is the problem?
        PeterJones @Ogün Kovan
        @ogün-kovan ,
        In Settings > Preferences > New Document, you might try picking the pulldown with ISO 8859-9 selected:
        But that’s technically for new files; I don’t know if Notepad++ will also use that for ANSI files.
        You might also try toggling Settings > Preferences > MISC > Autodetect character encoding.
        Ogün KovanO 1 Reply Last reply Reply Quote 0
          Ogün Kovan @PeterJones
          @peterjones yeah it is for new document not existing ones. i tried to disable and enable that option (autodetect character encoding) but didnt change anything. i dont get it :S
          maybe it has smth to do with windows LTSC 2021?
            @ogün-kovan said in turkish characters problem:
            There’s a good chance of that.
            If you look at the ? menu, Debug Info, what does it say for your Current ANSI codepage: xxxx ?
            (There were some recent discussions that you can search for in the forum which show where in windows to change the default codepage)
              @peterjones 1252 .
              can you give me link please :)
                @ogün-kovan
                https://community.notepad-plus-plus.org/topic/22636/debug-info-dialog-what-does-current-ansi-codepage-mean/5
                Those links are focused on changing the codepage to UTF8 (65001)… but should be able to work for changing to 1254 as well.
