    How do I toggle block comment?
    4 Posts 2 Posters 953 Views 1 Watching
    • nutnutwinN Offline
      nutnutwin
      Hi
      I see that there are
      Edit -> Comment/Uncomment ->
      • Toggle Single Line Comment
      • Single Line Comment
      • Single Line Uncomment
      • Block Comment
      • Block Uncomment
        But no “Toggle Block Comment”
        wonder if there workaround for this?
        (Seems available in VSCode, just an example
      Thank you so much.
        Ekopalypse @nutnutwin
        @nutnutwin
        The only “workaround” I see at the moment is to use one of the
        script plugins and do the necessary calculations to implement it.
        But can I ask you a serious question:
        Where do you see an advantage in using block comments over line comments?
        nutnutwinN 2 Replies Last reply Reply Quote 0
          nutnutwin @Ekopalypse
            @ekopalypse
            A very refreshing point indeed…
            Yes for many language with decent single line comment it is totally fine
            while for Markdown for example, only block comment is properly defined
            <!-- your comment -->
            the built-in markdown use “#” for single line comment, which is reserved for paragraphs in markdown
            Yes I can change to to like “//”, but is not compatible when I open the file in other Editors, say, VSCode.
            Thank you.
