    How to use Multiple Cursors (aka Multi-Editing) using Keyboard?
    7 Posts 5 Posters 27.5k Views 2 Watching
    • AmitA Offline
      Amit
      Is it possible to use Multiple Cursors (aka Multi-editing in Notepad++ Preferences > Editing) using Keyboard shortcut?
      For example, I can do Column editing mode using ALT + Shift + Up/Down arrows.
      Is there a way to do the same somehow for Multi Cursors? I can use Mouse click and it works find, but was wondering if there is a faster way to do so?
      Thank you.
      PeterJonesP Khatri VinayK 2 Replies Last reply Reply Quote 0
        PeterJones @Amit
        @amit ,
        Not that I am aware of.
        I am not sure how that would even work.
        With column-mode, you are arrowing through the box region you want to select, so you’re always “inside” the selection.
        With multi-select Ctrl+Click, you are literally clicking at multiple locations; I am not sure how you would be able to tell Notepad++ “I want to click HERE, THERE, and ANOTEHR”, with only using the keyboard.
        AmitA 1 Reply Last reply Reply Quote 1
        • AmitA Offline
          Amit @PeterJones
          @peterjones, here is one test case that I was trying. Let’s say, I want to add <li> tag to the following lines. If I use Column edit mode, I cannot effectively go to end of the line to add closing tag </li>. However, Multi-editing mode allows me to go to end of word using Ctrl + Right Arrow. However, I have to select the beginning of each line with Ctrl + Mouse Click, which I prefer to use keyboard shortcut.
          I understand, there are other ways to do the same, I was just wondering if there is a way to do it through multi-editing feature.
          <li>monday</li>
          <li>tuesday</li>
          <li>wednesday</li>
          <li>thursday</li>
          Thanks.
          (note: this is a simplified example.)
          Michael VincentM astrosofistaA 2 Replies Last reply Reply Quote 0
          • Michael VincentM Offline
            Michael Vincent @Amit
            @amit said in How to use Multiple Cursors (aka Multi-Editing) using Keyboard?:
            I think you want to install the “BetterMultiSelection” plugin based on what I think you’re asking.
            Cheers.
            • astrosofistaA Offline
              astrosofista @Amit
              @amit
              @Michael-Vincent is right, that is easily doable with the BetterMultiSelection plugin. After making the multiselection at the start of the lines and typing <li>, just press the end key to move to the end of the lines. Then you can type the ending tags.
              Here are links for more advanced examples involving the BetterMultiSelection plugin:
              https://community.notepad-plus-plus.org/post/53667
              https://community.notepad-plus-plus.org/post/54925
              https://community.notepad-plus-plus.org/post/51906
              https://community.notepad-plus-plus.org/post/53168 (explanation)
              https://community.notepad-plus-plus.org/post/51915
              https://community.notepad-plus-plus.org/post/51786
              Take care!
              AmitA 1 Reply Last reply Reply Quote 4
              • Khatri VinayK Offline
                Khatri Vinay @Amit
                • AmitA Offline
                  Amit @astrosofista
                  @astrosofista @Michael-Vincent, thank you. I will look into this and will try it out. Appreciate it.
