    Color Picker for 64bits doesn't work
    3 Posts 2 Posters 1.1k Views 1 Watching
    • Durand PaulD Offline
      Durand Paul
      I downloaded the last version of Notepap++ v8.3.3 but the plugin Color Picker for 64 bits donwloaded on this page https://github.com/vinsworldcom/nppQCP/releases/tag/2.1.0.2 doesn’t work with this version of Notepad++, how to fix this problem?
      Thank you for your answer.
      • Michael VincentM Offline
        Michael Vincent @Durand Paul
        @durand-paul said in Color Picker for 64bits doesn't work:
        Maybe try the latest version 2.1.2.1.
        Durand PaulD 1 Reply Last reply Reply Quote 3
          Durand Paul @Michael Vincent
          Thank you very much Michael for your answer, it work fine with this version https://github.com/vinsworldcom/nppQCP/releases/tag/2.1.2.1
