    Question about the Dark Mode's dark scrollbars and toolbars
    7 Posts 3 Posters 2.6k Views 2 Watching
    • Vitalii DovganV Online
      Vitalii Dovgan
      The Dark Mode in Notepad++ makes both the background and the scrollbars dark, as on the screenshot.
      The dark background is applied to the title bars of Notepad++‘es plugins and to some scrollbars in plugins’ windows.
      However, it is not applied to some plugins’ toolbars and to a scrollbar of a RichEdit control as can be seen on the another screenshot.
      Is there some specific code that needs to be added to plugins to fully support the Dark Mode?
      PeterJonesP rdipardoR 2 Replies Last reply Reply Quote 1
        PeterJones @Vitalii Dovgan
        @vitalii-dovgan ,
        Well, as of v8.4.1, there is the new messages NPPM_ISDARKMODEENABLED and NPPM_GETDARKMODECOLORS (which will eventually be documented at the usermanual, the next time it’s published)… but I don’t know if that’s sufficient for you to then change the colors of the toolbar yourself. (And, of course, it won’t work before v8.4.1)
        • rdipardoR Offline
          rdipardo @Vitalii Dovgan
          @vitalii-dovgan,
          watch this space: https://github.com/notepad-plus-plus/notepad-plus-plus/pull/11711
          Vitalii DovganV 1 Reply Last reply Reply Quote 3
            Vitalii Dovgan @rdipardo
            @rdipardo
            Wow, this is an impressive pull request! It definitely shows that the Dark Mode is not so easy to implement!
              PeterJones @PeterJones
              @peterjones said in Question about the Dark Mode's dark scrollbars and toolbars:
              It has been published:
              • NPPM_ISDARKMODEENABLED
              • NPPM_GETDARKMODECOLORS
              Vitalii DovganV 1 Reply Last reply Reply Quote 1
                Vitalii Dovgan @PeterJones
                Since Notepad++ 8.4.4 enhanced Dark Mode, the plugins’ docked dialogs seem to stop receiving the WM_CTLCOLOREDIT message. Is it something expected? If so, what is the alternative way of providing a custom colors for EDIT controls?
                rdipardoR 1 Reply Last reply Reply Quote 1
                • rdipardoR Offline
                  Possibly related: Plugin rendered wrong since v8.4.3
