    Replace sets of numbers in a given position with 0
    4 Posts 2 Posters 808 Views 2 Watching
    • Fernando BernabeuF Offline
      Fernando Bernabeu
      Hello!
      I’ve been trying to look for a solution to this problem I have by using Regular Expressions, but I’ve come up empty.
      I have a pose file for a 3D model and the line I want to modify looks like this:
      Hips: 5.5 5.5 2.8 -0.0248 -0.0071 -0.0215 1 1 1
      The first three sets of numbers between spaces are rotation, the next three are position and the last three are size. The position sets of numbers can have up to 4 decimal numbers.
      What I want to do is replace the position sets of numbers with 0, so I could end up with a line like this:
      Hips: 5.5 5.5 2.8 0 0 0 1 1 1
      Would there be a way to specifically replace the 4th, 5th and 6th set of numbers between spaces with 0?
      Big TIA
      • Neil SchipperN Offline
        Neil Schipper @Fernando Bernabeu
        @fernando-bernabeu
        Here’s a solution with a very loose spec. It doesn’t care what the contents of the first 4+3=7 fields are, only that they are chunks of text separated by a single space.
        Ctl-h
        Fi: ^(?:(?:.*? ){4})\K((?:.*? ){3})
        Re: 0 0 0 <=== trailing space needed!
        Mode=regex; option box unchecked
        Then: Replace All
        You don’t actually state that you want to do this for every occurrence in a file but that’s what I’ve assumed.
        Neil SchipperN 1 Reply Last reply Reply Quote 1
          Neil Schipper @Neil Schipper
          Here’s an expression with a somewhat tighter spec, in case file contains lines with different starting text you wish to ignore: ^Hips: (?:(?:.*? ){3})\K((?:.*? ){3})
          We can make it even tighter, such as validating that the other pieces consist of digits, maybe with decimal points, etc.
          Fernando BernabeuF 1 Reply Last reply Reply Quote 1
            Fernando Bernabeu @Neil Schipper
            @neil-schipper
            Thank you very much! That worked wonderfully!
