    Move Down Current Line doesn't work with Keyboard Shortcut
    3 Posts 2 Posters 690 Views 1 Watching
    • Jason R MayberryJ Offline
      Jason R Mayberry
      Move Down Current Line isn’t working with the keyboard shortcut (ctrl+shift+down). Am I missing something?
        Alan Kilborn @Jason R Mayberry
        @Jason-R-Mayberry said in Move Down Current Line doesn't work with Keyboard Shortcut:
        Yea, probably you are.
        As shipped, Notepad++ 8.4.3 (notice that I said my version, but you didn’t say yours, so…) has Ctrl+Shift+DownArrow set to the Move Down Current Line function, and it is working fine.
        You probably have some other program stealing the key via a globally set hotkey – check that.
        Jason R MayberryJ 1 Reply Last reply Reply Quote 1
          Jason R Mayberry @Alan Kilborn
          @Alan-Kilborn I was also using 8.4.3 (sorry about that).
          Thanks for the guidance. I use Razer headphones, and it turns out that it was the Razer software that was causing the problem. Thought I would share in case any other who had the same problem, and like me weren’t smart enough to figure it out on their own.
          Also, I’ve used Notepad++ for years (decades?) now, and absolutely love it. Just sent a donation to show my gratitude.
