    Python Script help, stop execution
    3 Posts 2 Posters 1.0k Views 1 Watching
    • skimmer333S Offline
      skimmer333
      Hi all,
      I’ve just started learning python and programming.
      I have written up a simple script which prompts for three separate bits of info, and then uses that to create a folder and saves the document/tab to that folder.
      So far it works ok. What I am now trying to achieve, is to stop the script if the Cancel button is selected on a prompt dialog box.
      My code is as follows. I’m testing just using the first prompt, hence the console.write. I just can’t figure out what I need to do. (Note, I don’t want to close Npp, just stop the script from continuing. Any assistance would be greatly appreciated.
      from Npp import editor, notepad
      import os
      vPath = 'H:\\INCs'
      vNum = notepad.prompt('INC : ','Enter INC#','')
      if vNum == None:
         console.write('None')
      vFI = notepad.prompt('FI: ','Enter FI','')
      vDesc = notepad.prompt('Desc: ','Enter Description','')
      vBuild = str(vPath) + '\\' + str(vNum) + '-' + str(vFI) + ' ' + str(vDesc)
      vBuildAll = vBuild +  '\\' + str(vNum) + '.txt'
      if not os.path.exists(vBuild):
         os.makedirs(vBuild)
      notepad.saveAs(vBuildAll);
        Ekopalypse @skimmer333
        @skimmer333
        You make a function and return from it.
        def main(directory):
            vNum = notepad.prompt('INC : ', 'Enter INC#', '')
            if vNum is None:
                return
        main(r'H:\INCs')
          skimmer333
          Thanks heaps. Makes sense to me now.
