    Help with codes
    2 Posts 2 Posters 505 Views 1 Watching
    • WayneW Offline
      Wayne
      Code for placing a border around a heading <h…>
        Terry R @Wayne
        @Wayne said in Help with codes:
        You seem to be referring to html code. This is the wrong forum to be asking that on. Even though you may be using Notepad++ (assumption), that does not make this the correct place for your question.
