    Macro for Open, Find and Replace and Save
    22 Posts 6 Posters 14.9k Views 2 Watching
    • José Luis Montero CastellanosJ Offline
      José Luis Montero Castellanos @Lycan Thrope
      @Lycan-Thrope :
      I will take your comments into account.
      Greetings :-)
      • Jaguar AsadJ Offline
        Jaguar Asad @guy038
        @guy038 said in Macro for Open, Find and Replace and Save:
        Hello, @josé-luis-montero-castellanos, @aln-kilborn and all,
        @josé-luis-montero-castellanos, regarding your regex S/R :
        • SEARCH (?s)(<St)(.)(/S)(.)(<Xt)(.)(/X)|(<Xt)(.)(/X)(.)(<St)(.)(/S)
        • REPLACE ?1\5\2\7\4\1\6\3:${12}${9}${14}${11}${8}${13}${10}
        Why do you need the leading in-line modifier (?s), in the search part ? Do you mean that the single char . in group 2, 4, 6, 9, 11 and 13 may also represent a line-break char ( \r or \n ) ?
        I suppose not ! Then, your correct search regex is rather :
        (?-s)(<St)(.)(/S)(.)(<Xt)(.)(/X)|(<Xt)(.)(/X)(.)(<St)(.)(/S)
        where any . single char will represent a non-break char, only !
        Now, I noticed that the groups used, in replacement, for each alternative of the search regex, are in the same order ! Then, you can use, preferably, a specific feature of the Boost Regex engine, called Branch Reset
        For instance, in your regex, the numbers of each group are :
        Gr : 1    2  3   4  5    6  7   |8    9  10  11 12   13 14
        If we use the Branch Reset feature the search regex becomes :
        (?-s)(?|(<St)(.)(/S)(.)(<Xt)(.)(/X)|(<Xt)(.)(/X)(.)(<St)(.)(/S))
        Gr:     1    2  3   4  5    6  7   |1    2  3   4  5    6  7
        Thus, your entire regex S/R can be simplified as below :
        • SEARCH (?-s)(?|(<St)(.)(/S)(.)(<Xt)(.)(/X)|(<Xt)(.)(/X)(.)(<St)(.)(/S))
        • REPLACE \5\2\7\4\1\6\3
        For instance, given this INPUT text :
        <St2/S4<Xt6/X
        <Xt9/XB<StD/S
        You would get the OUTPUT text, below :
        <Xt2/X4<St6/S
        <St9/SB<XtD/X
        Notes :
        • The Regular expression option must be selected
        • Preferably, tick the [Wrap around](https://www.ahijoy.com/) option
        I tried it but didn’t work
