    Using sets to find A-Za-z plus the # and - chars ..?
    23 Posts 6 Posters 4.3k Views 2 Watching
      Alan Kilborn @Andrew McP
      @Andrew-McP said in Using sets to find A-Za-z plus the # and - chars ..?:
      I really admire you guys for figuring out Regular Expressions
      So if someone says they have “figured out regular expressions”, I pity them. Because it just means they are ripe for an upcoming whipping when a regex misunderstanding of theirs really embarrasses them. :-)
      It pays to always be humble when discussing regular expressions with others. :-)
      I bet you never get lost
      GPS!
      I like the trick of having - as last character before ]
      Not so much a trick, as a logical place to put it when you realize that anywhere except the first or last position it must form some sort of “range”.
      Andrew McPA 1 Reply Last reply Reply Quote 1
      • Andrew McPA Offline
        Andrew McP @Alan Kilborn
        @Alan-Kilborn hahahah yes no way would I bet my house on any regular expression I recommend covering all, no matter how perverse, eventualities…
          Hello, @peterjones,
          In my previous post, I forgot to mention the ^ character, which has a special meaning within a Character class !
          So, here is an updated version of my previous post :
          If we consider the following CHARACTER CLASS structure :
          123456789
          The POSSIBLE location(s), in order to find the LITERAL character below, are :
          LITERAL Character [    :     POSSIBLE at any position, BETWEEN 2 to 8
                                       POSSIBLE at any position, BETWEEN 2 to 8, if PRECEDED with an ANTI-SLASH character
          LITERAL Character ]    :     POSSIBLE at position 2 ONLY
          LITERAL Character -    :     POSSIBLE at position 2
                                       POSSIBLE at position 8
          LITERAL character ^    :     POSSIBLE at any position, BETWEEN 3 and 8
          LITERAL Character \    :     POSSIBLE at any position, BETWEEN 2 to 8, if PRECEDED with an ANTI-SLASH character
          And I suppose that @alan-kilborn could add :
          To use a “literal ^” in a character class: Use it directly like any other character, e.g. [ab^c], but right after the opening [ of the class notation ; “escaping” is not necessary (but is permissible), e.g. [ab\^c]
