    How do you make a note pade file .ush for unreal engine
    2 Posts 1 Posters 878 Views 1 Watching
    • Emile BrouillardE Offline
      Emile Brouillard
      i would like to have a file type of style .ush so i can code a slime with raymarching on my unreal engine project but i cant seem to figure out how to have my file type to go to .ush does someone know why ??
      thanks in advance
      here is a pic of what the file type should look like
        Emile Brouillard
        i figured it out in the end it was just a mather of renaming the text file type in the right hierachy of folder for unreal . So you need to rename it in .ush and with all folder type engaged and your good when you see fichier USH27e0e338-1dd6-4051-bd4c-f0a1d7df2ad5-image.png
