    Issue setting text color for quotes in XML style
    3 Posts 2 Posters 827 Views 1 Watching
    • Victor NonyaV Offline
      Victor Nonya
      can use some help editing an XML style for notepad++
      I found this xml online and didn’t like the colors so I have been adjusting colors but I’m having an issue setting the colors for strings, etc such as anything between ‘’ or “” I’m not sure what wordstyle I should be using I’ve tried several as you can see in the code and the string text is dark blue no matter what I use. The color scheme is Black Board for the styles. It’s my preferred style for notepad++ so I’m trying to create this language style for that. In case someone wanted to test the colors out.
      <NotepadPlus>
          <UserLang name="Tradingview Pine Script" ext="pine" udlVersion="2.1">
              <Settings>
                  <Global caseIgnored="no" allowFoldOfComments="yes" foldCompact="no" forcePureLC="0" decimalSeparator="0" />
                  <Prefix Keywords1="no" Keywords2="yes" Keywords3="no" Keywords4="yes" Keywords5="no" Keywords6="yes" Keywords7="no" Keywords8="no" />
              </Settings>
              <KeywordLists>
                  <Keywords name="Comments">00// 01 02 03 04</Keywords>
                  <Keywords name="Numbers, prefix1"></Keywords>
                  <Keywords name="Numbers, prefix2"></Keywords>
                  <Keywords name="Numbers, extras1"></Keywords>
                  <Keywords name="Numbers, extras2"></Keywords>
                  <Keywords name="Numbers, suffix1"></Keywords>
                  <Keywords name="Numbers, suffix2"></Keywords>
                  <Keywords name="Numbers, range"></Keywords>
                  <Keywords name="Operators1">=> ( ) ? : < > == = , + - / * !=</Keywords>
                  <Keywords name="Operators2">and or not</Keywords>
                  <Keywords name="Folders in code1, open"></Keywords>
                  <Keywords name="Folders in code1, middle"></Keywords>
                  <Keywords name="Folders in code1, close"></Keywords>
                  <Keywords name="Folders in code2, open"></Keywords>
                  <Keywords name="Folders in code2, middle"></Keywords>
                  <Keywords name="Folders in code2, close"></Keywords>
                  <Keywords name="Folders in comment, open"></Keywords>
                  <Keywords name="Folders in comment, middle"></Keywords>
                  <Keywords name="Folders in comment, close"></Keywords>
                  <Keywords name="Keywords1">study
      avg min max cum
      security
      fill input input.bool input.color input.int input.string ta.ema ta.sma barcolor bgcolor
      iff nz abs round fixnan
      time timestamp timeinrange
      sma ema donchian stdev linreg rsi
      hline plot plotarrow plotshape
      lowest highest</Keywords>
                  <Keywords name="Keywords2">title color text
      overlay shorttitle
      step maxval minval defval type options
      linestyle linewidth style transp editable
      </Keywords>
                  <Keywords name="Keywords3">true false
      isintraday
      black blue cyan gray green lime olive orange red silver white
      na
      circles
      float integer string bool string
      close open high low volume</Keywords>
                  <Keywords name="Keywords4">//@version=</Keywords>
                  <Keywords name="Keywords5">if else
      </Keywords>
                  <Keywords name="Keywords6">shape.
      barstate.
      location.
      size.</Keywords>
                  <Keywords name="Keywords7">color</Keywords>
                  <Keywords name="Keywords8">size</Keywords>
                  <Keywords name="Delimiters">00' 01 02' 03 04 05 06" 07 08" 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23</Keywords>
              </KeywordLists>
              <Styles>
                  <WordsStyle name="DEFAULT" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="COMMENTS" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="LINE COMMENTS" fgColor="808080" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="NUMBERS" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS1" fgColor="5b9cf6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS2" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS3" fgColor="ff848c" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS4" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS5" fgColor="5897ed" bgColor="131722" fontName="" fontStyle="1" nesting="0" />
                  <WordsStyle name="KEYWORDS6" fgColor="008080" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS7" fgColor="5b9cf6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="KEYWORDS8" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="OPERATORS" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="FOLDER IN CODE1" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="FOLDER IN CODE2" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="FOLDER IN COMMENT" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS1" fgColor="000080" bgColor="131722" fontName="" fontStyle="2" nesting="2" />
                  <WordsStyle name="DELIMITERS2" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS3" fgColor="000080" bgColor="131722" fontName="" fontStyle="2" nesting="0" />
                  <WordsStyle name="DELIMITERS4" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS5" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS6" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS7" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
                  <WordsStyle name="DELIMITERS8" fgColor="dce5f6" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
      	    <WordsStyle name="STRING" styleID="7" fgColor="06761e" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
      	    <WordsStyle name="CHARACTER" styleID="7" fgColor="06761e" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
      	    <WordsStyle name="DOUBLESTRING" styleID="6" fgColor="06761e" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
      	    <WordsStyle name="SINGLESTRING" styleID="7" fgColor="06761e" bgColor="131722" fontName="" fontStyle="0" nesting="0" />
              </Styles>
          </UserLang>
      </NotepadPlus>
        Ekopalypse @Victor Nonya
        @Victor-Nonya
        Instead of editing the XML file directly, use the dialog “Language->User defined language->Define your language …”.
        and define a delimiter using " as open and close tag.
        Victor NonyaV 1 Reply Last reply Reply Quote 3
          Victor Nonya @Ekopalypse
