    Macro with Encoding... Char Sets... OEM-US Does Nothing
    2 Posts 2 Posters 693 Views 1 Watching
    • TheSimArchitectT Offline
      TheSimArchitect
      Hi! I recorded a macro to change the Character Set used to OEM-US so I don’t have to navigate the menu each time I am editing a file with such encoding, but the macro does nothing.
      This is the macro recorded inside the file shortcuts.xml:
          <Macros>
              <Macro name="OEM US" Ctrl="no" Alt="no" Shift="no" Key="0">
                  <Action type="0" message="2422" wParam="0" lParam="0" sParam="" />
                  <Action type="0" message="2325" wParam="0" lParam="0" sParam="" />
              </Macro>
          </Macros>
      Does anybody know what could be wrong? I didn’t associate a shortcut because I am happy to run it by clicking on Macro… OEM US.
      I don’t want to change the default encoding. I use Code Page 437 only when editing batch scripts. Thanks for any idea, even being able to bookmark that option would be good too, so I don’t have to spend half minute each time I open a file, it’s ok for a single file but not when you have a dozen!
        Alan Kilborn @TheSimArchitect
        @TheSimArchitect
        Maybe try:
                    <Action type="2" message="0" wParam="45044" lParam="0" sParam="" />
                </Macro>
