    Clickable Link (file://) problem
    8 Posts 4 Posters 1.6k Views 2 Watching
    • rthxR Offline
      rthx
      Clickable Link (file://) Systemfile-URL opens a cmd window instead of an explorer window as expected.
      All paths are opened in a cmd window instead of an explorer window. Exception are only the root paths (C:, D:\ …).
      Examples:
      file://C:/ -> opens an explorer window as desired
      file://C:\ -> opens an explorer window as desired
      file://C:/Windows/ -> opens cmd window instead of an explorer window.
      file://C:\Windows\ -> opens cmd window instead of an explorer window.
      file://C:\Windows -> opens cmd window instead of an explorer window.
      Debug-Info
      Notepad++ v8.5.4 (32-bit)
      Build time : Jun 17 2023 - 20:40:14
      Command Line :
      Cloud Config : OFF
      OS Version : 22H2
      OS Build : 19045.3086
      Current ANSI codepage : 1252
        Alan Kilborn @rthx
        @rthx
        On my system, ALL of your examples open an Explorer window.
          Coises
          @rthx What happens when you type WindowsKey+R (opening a “Run” dialog box), type file://C:/Windows/ in the box, and press Enter?
          If that also opens a command window, then I think there is something unusual in your Windows registry settings.
          rthxR 1 Reply Last reply Reply Quote 3
          • rthxR Offline
            rthx @Coises
            Addendum1
            I have of course, before posting here, tried this on different systems. I have the same phenomenon on 4 physical PCs (all Win10, two of them notebooks) and several VMs (Win10 and Win11) in VirtualBox.
            Seems to me already somehow related to the system - but on all of them?
            Addendum2
            In another application “wikidPad 2.2” all above links open in an explorer window. The same on systems with Windows 7 and Notepad++.
            @Coises “Run” (dialog box), file://C:/Windows/ is the same, opens a cmd window. In all the above systems.
            @Alan-Kilborn on which system?
            Alan KilbornA PeterJonesP CoisesC 3 Replies Last reply Reply Quote 0
              Alan Kilborn @rthx
              @rthx said in Clickable Link (file://) problem:
              Notepad++ v8.5.4 (64-bit)
              Build time : Jun 17 2023 - 20:42:45
              Path : C:\NotepadPlusPlus\Misc_NoBackup\Releases\npp.8.5.4\npp.8.5.4.portable.x64\notepad++.exe
              Command Line : -titleAdd=“8.5.4 64-bit” -multiInst
              Local Conf mode : ON
              Cloud Config : OFF
              OS Name : Windows 11 Pro (64-bit)
              OS Version : 22H2
              OS Build : 22621.1992
              Plugins :
              mimeTools (2.9)
              NppConverter (4.5)
              PythonScript (3.0.16)
                PeterJones @rthx
                Addendum1
                If you set up your OS options the same when you set them up, that is a likely possibility.
                Addendum2
                Most likely, “wikidPad 2.2” (whatever that is) does its own interpretation of that kind of link, instead of passing the link unedited to the OS to say “run this link as you normally would”.
                Then that proves that the native interpretation of that kind of link on all the above systems is to open that kind of link in cmd window instead of in Explorer. You will need to find a forum that is good with helping people with generic windows questions, and ask “on my old Win 7 machines, when I would run file://c:/Windows/ from the Windows Run menu, it would open that directory in the windows explorer. But in a bunch of Win 10 and Win 11 machines and VM, if I run that same URL, it opens them in cmd.exe instead. How do I get them to open that file URL in Windows Explorer?”
                on which system?
                And on mine:
                Command Line :
                Cloud Config : OFF
                OS Version : 22H2
                Plugins : ...
                  Coises @rthx
                  If you are comfortable doing this, open regedit and see what is the default value for the key HKEY_CLASSES_ROOT\Folder\shell\open\command. On my system it is %SystemRoot%\Explorer.exe. I’m going to guess that it is different on the systems that open a command window.
                  If the above didn’t make any sense to you, skip it.
                  The behavior with the Run box is not standard for a Windows 10 system, so something has changed it. What would do that, and why, I can’t guess.
                  • rthxR Offline
                    rthx
                    The problem is solved - thanks to all who responded!
                    Especially the tip from @PeterJones and @Coises has brought me closer to the solution, I now knew where to look.
                    It was actually registry entries (from “Open Command Prompt here” Context Menu), which I have been using since Windows 7 (without the problem). And since it was so handy, of course I used that on all my systems.
                    That’s where Win10 behaves differently than Win7.
                    Source: Enhancing the “Open Command Prompt here” Context Menu experience
                    After removing these registry entries the problem is solved.
