    Syntax Highlighting (BASH/shell) question/bug
    6 Posts 3 Posters 6.6k Views 2 Watching
    • Trevor ST Offline
      Trevor S
      Hello, hopefully this is something simple I’ve missed, but I just updated N++ (Debug Info at bottom) and a bash script I’ve been working on now has an issue with syntax highlighting. The highlighting of what appears to be a $( ) block starts, but never finishes, effectively blocking the highlighting of the rest of the file. I have attached a screen snip of a few lines surrounding the start of the issue. Line 60 was added just to show that it works sometimes, and I verified that there are only spaces and tabs for whitespace on line 61. Why is the highlighting not stopping at where the red arrow points?
      Debug Info:
      Notepad++ v8.5.4   (64-bit)
      Build time : Jun 17 2023 - 20:42:45
      Command Line : "Z:\reposync\doReposync.sh"
      Cloud Config : OFF
      OS Name : Windows 10 Home (64-bit)
      OS Version : 22H2
      OS Build : 19045.3324
      Current ANSI codepage : 1252
      Plugins :
          mimeTools (2.9)
          NppConverter (4.5)
        PeterJones @Trevor S
        @Trevor-S ,
        That is known.
        It is described here and here as being the result of a change made in one of the libraries that Notepad++ uses, called “Lexilla”.
        The Lexilla team has fixed the issue on their end; the fix is in Lexilla v5.2.6.
        The newest Notepad++ release v8.5.5 includes Lexilla v5.2.6, so that version should hopefully fix your problem. (If you’re wondering why your just-updated Notepad++ v8.5.4 is older than the most recent v8.5.5, it’s because v8.5.5 is brand new and hasn’t been triggered for auto-update yet.)
        Michael VincentM Trevor ST 2 Replies Last reply Reply Quote 3
        • Michael VincentM Online
          Michael Vincent @PeterJones
          @PeterJones said in Syntax Highlighting (BASH/shell) question/bug:
          @Trevor-S :
          Is this what you expect?
          Cheers.
          Trevor ST 1 Reply Last reply Reply Quote 1
          • Trevor ST Offline
            Trevor S @PeterJones
            @PeterJones Thanks for the great info and explanation! Is there a way I can mark my question answered or equivalent?
            I manually updated to 8.5.5 and am now seeing the behavior I expect. Thanks again!
            Edit: Added more results.
            • Trevor ST Offline
              Trevor S @Michael Vincent
              @Michael-Vincent Yes indeed, thanks!
                Michael Vincent @Trevor S
                @Trevor-S said in Syntax Highlighting (BASH/shell) question/bug:
                Great! Then if you’re comfortable, upgrade now since 8.5.5 is available; otherwise, wait for the autoupdate usually about 7-10 days after the release - if all goes well.
                No need to mark the question answered, it just stays like this for posterity.
                Cheers.
