    How do I join specific long lines that should be a single line (was: "Help.. how to...")
    12 Posts 4 Posters 4.8k Views 2 Watching
    • Un KnownU Offline
      Un Known
      Hi, first of all apologies for my English…
      I got a document in notepad++
      The problem is that it is a document with 325 questions and I want to import them to Moodle in the Aiken format…
      Some of the questions have, the questions and some answers in MORE than ONE line… and I can’t import them because of that, so…
      Is there a way to “select” those more than one lines in the questions or answers and convert them in a single line question or answer?
      Example
      Question:
      1- Blab bla bla bla
      blalbla?:
      A) lksjdfljksldfkj
      lkjsdflkjsdf
      B ) irfiifiif
      C) iasiaflikfasdlkjf
      D) ioririf
      As you can see question 1 has two lines and answer A has two lines… how can i “find” all of those situations in notepad++ and replace them for a single line? Or at least the most easy way…
      What I want:
      1- Bla bla bla bla bla?:
      A) ajsdkdjaskjadks
      B) klasddasklj
      C) ajklsddasjkldsa
      D) sjkldfoads
      Thanks.
      1. moderator added code markdown around text; please don’t forget to use the </> button to mark example text as “code” so that characters don’t get changed by the forum
      2. moderator updated title of post per discussion below
        Terry R @Un Known
        @Un-Known said in Help.. how to...:
        Yes, and it uses regular expressions. In your example of data before the changes are made you show answer B as having a space between the B and the ). I’m assuming that was a mistake and my solution assumes the same.
        So using the Replace function and with search mode set to “regular expression” we have:
        Find What:\R(?!=\d+-|[ABCD]\))
        Leave the Replace With field empty, so this will delete the end of line where necessary.
        Test this by using the Replace button only. Once you are happy with the result you could use the “Replace All” button which will complete the changes in the document. Make sure you work with a copy of the document, that’s always a good idea when deleting/altering stuff, at least for the first time.
          PeterJones @Terry R
          @Terry-R,
          Do you want to leave it empty, or replace it with a space?
          I think yours was too aggressive, even with a space:
          BEFORE
          Question:
          1- This question originally spread
          across multiple lines?:
          A) This answer also started
          as two lines
          B) To Be or Not To Be
          C) I am not right
          D) Don't even think of guessing D
          9- Short Question
          A) Short Answer
          B) Be Short
          C) See, I am short
          D) Done
          13- Another question originally spread
          A) Apples
          B) Not the answer,
          but spread across multiple lines
          C) Cats!
          D) Dogs. Run away,
          run away!
          AFTER (without space)
          Question:1- This question originally spreadacross multiple lines?:
          A) This answer also startedas two lines
          C) I am not right
          D) Don't even think of guessing D...9- Short Question
          A) Short Answer
          B) Be Short
          C) See, I am short
          D) Done13- Another question originally spreadacross multiple lines?:
          A) Apples
          B) Not the answer,but spread across multiple lines
          C) Cats!
          D) Dogs. Run away,run away!
          AFTER (with space):
          Question:  1- This question originally spread across multiple lines?:
          A) This answer also started as two lines
          C) I am not right
          D) Don't even think of guessing D  ...  9- Short Question
          A) Short Answer
          B) Be Short
          C) See, I am short
          D) Done  13- Another question originally spread across multiple lines?:
          A) Apples
          B) Not the answer, but spread across multiple lines
          C) Cats!
          D) Dogs. Run away, run away!
          I was going to suggest something like ^(\d+-|[A-Z]\))(.*?)\R((?!\d+-|[A-Z]\)|\R).*$) replace with $1$2 $3, but you beat me again, and I think a hopefully-small tweak to yours would bring it in to working, without getting as complicated as mine.
          @Un-Known ,
          When asking questions, it’s best to have a meaningful title (even if you have to translate it from your native language). “Help… how to…” doesn’t tell the person looking at the list of posts anything about your post. On the other hand, “How do I join specific long lines that should be a single line” would tell the reader instantly what you are trying to do.
          Also, given this is a search-and-replace question, here are some useful references for helping you ask such questions, which helps us give better answers.
          • Please Read Before Posting
          • Formatting Forum Posts
          Alan KilbornA T PeterJonesP 3 Replies Last reply Reply Quote 2
            Alan Kilborn @PeterJones
            @PeterJones said in Help.. how to...:
            A moderator should change this thread’s title to exactly that. :-)
              Terry R @PeterJones
              @PeterJones said in How do I join specific long lines that should be a single line (was: "Help.. how to..."):
              Very possibly. I was looking at the examples provided and of course it’s just made up stuff, gibberish. The after examples don’t match up either with blabla becoming bla bla.
              So I assumed there will likely be a bit of to and fro before OP becomes happy. My solution at least will let them know it’s possible and they need to sort out proper examples!
              PS next time provide your solution before using moderator abilities to adjust examples and you might beat me ;-))
                PeterJones @PeterJones
                @Terry-R ,
                Good point. But since I wrote what follows, I’ll at least present it as the best starting point for the user
                FIND = (?<![\r\n])\R(?!=\d+-|[ABCD]\)|\R) – adds a check to make sure that the previous line wasn’t also a newline and that the next line after the matched line isn’t a newline (thus allowing spaces between questions and answers)
                From my data above, this slight tweak to @Terry-R’s regex gives
                NEXT TRY:
                Question:
                C) I am not right
                9- Short Question
                A) Short Answer
                B) Be Short
                C) See, I am short
                D) Done
                A) Apples
                C) Cats!
                … which I think is a reasonable merging of the data. And if there are some questions/answers spread over three or more lines, just run the regex more than once, until nothing changes.
                • Un KnownU Offline
                  Un Known
                  First of all sorry for all the mistakes… reading the answers it seems the leaving spaces where there where supposed not to be and not using words, made things difficult.
                  Sorry… As i said English is not my mother tongue.
                  Example 1
                  1- What’s your
                  name?:
                  A) Juan
                  B) Pedro de
                  la Fuente Rodriguez
                  C) Oscar
                  D) Alfredo
                  What I want:
                  1- What’s your name?:
                  A) Juan
                  B) Pedro de la Fuente Rodriguez
                  C) Oscar
                  D) Alfredo
                  Sorry again, I supposed that you will guess that my mistakes where from just not being meticulous while writing… my bad.
                  I assume Terry’s answers is the correct one, thanks. I will try that.
                    Terry R @Un Known
                    @Un-Known said in How do I join specific long lines that should be a single line (was: "Help.. how to..."):
                    We don’t want you to assume. Try both and see what each does to your data, make sure you work on a copy of the document! Because you didn’t give us real data (a common issue we have when trying to help) it’s often a guessing game and will often take several posts both by yourself and the solution provider to get one that works for you.
                    Un KnownU 1 Reply Last reply Reply Quote 0
                    • Un KnownU Offline
                      Un Known
                      As you can see the problem I have using Terry’s solution is that questions and the correct answer are in the same line.
                      I will try to post this better. I did it bad. Sorry.
                      Example:
                      1- What’s your
                      name?:
                      A) Juan
                      B) Pedro de
                      la Fuente Rodriguez
                      C) Oscar
                      D) Alfredo
                      ANSWER: D
                      What I want:
                      A) Juan
                      C) Oscar
                      D) Alfredo
                      ANSWER: D
                      Sorry I omitid things like the field ANSWER because when i was talking about Moodle in the Aiken format I supposed people would know beforehand… Really sorry for not explaining things in the correct way. Really, sorry.
                      • Un KnownU Offline
                        Un Known @Terry R
                        Really sorry. I know now that i did it bad.
                          PeterJones @Un Known
                          That’s what I tried to tell you in my follow-on posts.
                          But now that you’ve also told us that a line starting with ANSWER is also in the data, my previous suggestion will need to be tweaked.
                          Please try this suggestion:
                          FIND WHAT = (?<![\r\n])\R(?!=\d+-|[ABCD]\)|ANSWER|\R)
                          REPLACE WITH = \x20 (or you could type a space character in the REPLACE WITH box).
                          I believe that will work for you. (At least, it does with your most recent data)
                          Un KnownU 1 Reply Last reply Reply Quote 2
                          • Un KnownU Offline
                            Un Known @PeterJones
                            Peter jones
                            THANK YOU SO MUCH!!! that worked!
