    Setting Right Side Margin
    3 Posts 3 Posters 2.1k Views 1 Watching
    • Bill MillerB Offline
      Bill Miller
      I have just loaded version 8.5.8 and the one thing I can’t figure out is how to correct the alignment of type on a page so that sentences do not run on and on all the way to where it is necessary to right scroll to follow them. I would have thought it would be easy enough to set new tabs in Margins/Border/Edge under Settings/Preferences but I can’t make any progress. Can someone please suggest how to set the right side margin of a page so as to see everything lined up without the need to scroll across to the right? Hopefully the explanation of my issue was clear.
      CoisesC Michael VincentM 2 Replies Last reply Reply Quote 1
        Coises @Bill Miller
        @Bill-Miller You probably want, from the main menu bar, View | Word wrap — it’s a toggle (click to check if unchecked, click to uncheck if checked).
        This doesn’t affect the contents of the file, just the way it is displayed.
        • Michael VincentM Offline
          Michael Vincent @Bill Miller
          @Bill-Miller
          From the menu:
          View => Word wrap
          Otherwise, what you are asking is not really possible in a text editor. Try a word processor instead.
          Cheers.
