    NPP 8.6 multi-edit preference not shown?
    13 Posts 7 Posters 3.9k Views 3 Watching
    • Hans TroostH Offline
      Hans Troost
      Do I overlook something? Please find attached the Settings–Preferences–>Editing dialog box.
      I don’t see the “enable multi-edit”-option (or something like that).
      Can someone please indicate that option to me?
      • Alan KilbornA Online
        Alan Kilborn @Hans Troost
        @Hans-Troost said in NPP 8.6 multi-edit preference not shown?:
        It isn’t needed; never really has been needed IMO.
        Mutli-editing (i.e., multiple carets at the same time) is always enabled now.
        mkupperM László BotkaL 2 Replies Last reply Reply Quote 3
        • mkupperM Offline
          mkupper @Alan Kilborn
          @Alan-Kilborn said in NPP 8.6 multi-edit preference not shown?:
          I am really hoping an enable/disable get added for Mutli-caret-editing. With v8.6 I find myself constantly fighting with npp as multiple carets switch on automatically and tend to not switch off. So far I have resisted going back to v8.5.8 in hopes I could some up with a pattern for using npp v8.6 successfully.
          I’m a keyboardist who also uses column mode several dozen times a day. For example, consider:
          abcd
          abcde
          abcdef
          I want to replace the letter c with x and so keyboard over to get the text cursor between the first ‘b’ and ‘c’. I then do Shift+Alt+Down-arrow twice then Shift+Alt+right arrow. I do things like this dozens of times a day and so it’s automatic for me with holding the Shift+Alt keys down as I do down-down-right to make the selected column. I also frequently copy paste columns.
          Getting back to the example, npp is in column mode now for a 3x1 column with the letter ‘c’ selected.
          Aside - I just got screwed by npp v8.6 again… I was thinking ahead about this forum message and realized I wanted to document both v8.6 and v8.5.8 behavior. I alt-tab to the command prompt run np c:\tmp\tmp to open a tab with that file intending to also then open c:\tmp\tmp in npp v8.5.8. As I opened c:\tmp\tmp I’m back in npp v8.6 at the c:\tmp\tmp tab and so do Ctrl+PageUp to get to the tab where I had that 3x1 column with the letter ‘c’ selected. I automatically do down-arrow, hold the shift key down and up-arrow five times. Ctrl-C, Ctrl-PageDown, Ctrl-V, and realized I had been bitten by the multi-caret thing again.
          What happened is that when I did that down arrow from the 3x1 selection npp switched from column mode to multi-caret mode. As I did the shift-up-arrows it was creating three separate selections.
          So, let’s reproduce:
          • Using the keyboard select the letter ‘c’ column as before.
          • Down-arrow once to get to the line below the abcdef one.
          • While holding the shift key down do up-arrow five times.
          • You will see that all of the test lines are selected and the cursor is above the ‘1’ line.
          • Ctrl-C to load the selection(s) into the copy/paste buffer and you will get:
          abcd
          abc
          22
          abcd
          abcde
          abc
          abcd
          abcde
          abcdef
          Now, maybe that was what you wanted, but I expected:
          abcd
          abcde
          abcdef
          which is exactly what I get from v8.5.8.
          Now, if it was easy to exit from multi-caret it’s likely I could get used to have it pop-on automatically. For example, let’s do that column select of ‘c’ as before and type the letter ‘x’ so that we have:
          abxd
          abxde
          abxdef
          Notice that npp is now in multi-caret mode. My automatic response is to tap the Esc key. Nothing happens… To get out of multi-caret mode I need to use an arrow key (it does not matter which one) and then tap the Esc key.
          It seems that npp has two multi-caret modes. One, which I call persistent multi-caret mode ignores the Esc key. I call the other one fragile multi-caret mode and Esc works.
          Now I could get used to using an arrow key and to switch from persistent to fragile mode and then Esc to get back to normal single caret but this creates another problem which is that the cursor is left in an odd place. It turns out I need to then reverse the cursor movement I did to switch from persistent to fragile mode and then I’m back to close to where I was before the battle.
          I think my wish list for npp v8.6.1 is:
          • An option to disable multi-caret mode entirely. This restores the pre-v8.6 behavior.
          • An option to disable automatic switching from column to multi-caret mode. A person can still create multiple carets with Ctrl mouse-click.
          • An option to disable persistent multi-caret mode. The Esc key should always work.
          • An option to exit from multi-caret mode if I use the up or down arrows. Nearly all of my battles with v8.6 started because npp switched to multi-caret, I’m focused on what I’m working on, and do up or down arrow(s) to get to the line I want to get to and don’t notice right away that the multiple carets are screwing up my file as I type.
          • An option to control that when in multi-carat mode and left-arrow is used to exit from multi-carat mode if any of the carets go past column one.
          • An option to control that when in multi-carat mode and right-arrow is used and one or more of the carets is about to go off the right edge of a line to either turn multi-caret mode off or to remain in multi-caret mode but to allow the cursor(s) to go past the right edge(s) of lines. The latter would make keyboard’s column mode much like the mouse’s column mode where we are allowed to use the mouse click past the end of the lines.
          • Michael VincentM Online
            Michael Vincent @mkupper
            @mkupper said in NPP 8.6 multi-edit preference not shown?:
            Unless I’m misunderstanding how you get this behavior, I cannot replicate it.
            abcd
            abcde
            abcdef
            1. put caret between b and c on line 4.
            2. while holding Alt+Shift , press down arrow arrow twice
            3. While holding Shift, press right arrow once (the column of c’s are now highlighted)
            4. press x (column of c’s now change to a column of x’s)
            5. press ESC - single caret now blinks between x and d in line 6
            Cheers.
            EDIT: OH, I see you are using Alt+Shift in step 3. In that case, I can replicate. I’m in the habit of using Alt+Shift to create the “column caret” - which should really just be a special case of generic multi-caret and then use just Shift to continue to select what I want or no modifier to move the multi-caret “column”. You could also just install BetterMultiSelection if you’re really doing lots of column / multi-selecting. I don’t know how anyone could have done multi-caret and lived without this plugin up to (and potentially including) this point. I still have it enabled on my daily driver N++ 8.6 even with the new multi-editing enhancements.
              I have not made the move to 8.6 yet, but I think in @mkupper 's scenario I would not release the Alt key and thus would get into the same situation. Perhaps an official bug report is in order.
              • mkupperM Offline
                I’m still trying to figure out if the issues I have are bugs or features.
                A few days ago I filed bug report about v 8.6 column delete also deleted unexpected end-of-lines #14426
                • László BotkaL Offline
                  László Botka @Alan Kilborn
                  If I understand correctly, this part in Editing/Multi Editing of the user manual is no longer true:
                  Whether or not you can use Multi-Editing mode is determined by the Settings > Preferences > Editing > ☑ Enable Multi-Editing (Ctrl+Mouse click/selection) checkbox: with it checkmarked, Ctrl+Click will add caret locations; with it not checkmarked, Multi-Editing is disabled.
                  Caleb KnorrC PeterJonesP 2 Replies Last reply Reply Quote 1
                  • Caleb KnorrC Offline
                    Caleb Knorr @László Botka
                    @ László-Botka This is not correct. The checkbox was removed in 8.6.
                      PeterJones @László Botka
                      @László-Botka said in NPP 8.6 multi-edit preference not shown?:
                      The User Manual was updated about 24 hours ago to correctly describe the change to v8.6 (you might need to to Ctrl+Reload in your browser to get the updated copy of the page):
                      The manual still mentions the setting so that people who have the new version and are looking in the manual for where that setting went can see that the option was removed, and so that people who are still on an earlier version can still find the documentation for the option that their instance of Notepad++ still uses.
                      @Caleb-Knorr replied,
                      You misunderstood @László-Botka: they were saying that the old documentation (which described the checkbox without a caveat) did not match the new behavior, because the old documentation said there was a checkbox but v8.6 doesn’t have the checkbox. But apparently @László-Botka was looking at a cached version of the User Manual, because the new version of the User Manual was published to the website about 24 hours ago (which was before @László-Botka’s post).
                      László BotkaL Caleb KnorrC 2 Replies Last reply Reply Quote 3
                        László Botka @PeterJones
                        @PeterJones thanks the info!
                          Caleb Knorr @PeterJones
                          @ PeterJones I see, that is my bad. Do you know of any way to disable multi-editing, since the checkbox is gone?
                            Alan Kilborn @Caleb Knorr
                            @Caleb-Knorr said in NPP 8.6 multi-edit preference not shown?:
                            Perhaps disabling it via a PythonScript would work.
                            But is there really a big need for this?
                            Or is it just a matter of getting used to a new and potentially better capability, if you keep an open mind about new and better things?
                            mkupperM 1 Reply Last reply Reply Quote 1
                            • mkupperM Offline
                              We pounded rocks the same way for about 1.5 million years. About 50,000 years ago was the start of an explosion of developing and accepting new techniques. I have long been fascinated by this as I suspect that early humans from even a million years ago were about as intelligent as today’s humans but they seemed to either not try or to not accept variations in how rocks should be pounded. See https://www.history.com/news/hunter-gatherer-tools-breakthroughs for a timeline that lead to Notepad++.
                              I’m still in my cave, resisting Notepad++ v8.6’s automatic multi-carets…
