    can i ask for help
    3 Posts 3 Posters 597 Views 2 Watching
    • LupusL Offline
      Lupus
      so in a file i have line
      <Space_Tactical_Unit_Cap>25</Space_Tactical_Unit_Cap>
      and i have many same lines witch difrent numbers i remember there wos option to write something like
      <Space_Tactical_Unit_Cap>.*</Space_Tactical_Unit_Cap> to find the line no matter the number but i do not remember what exactgly i need to write in betwen this lines to manager find it please help
      Mark OlsonM PeterJonesP 2 Replies Last reply Reply Quote 1
      • Mark OlsonM Offline
        Mark Olson @Lupus
        @Lupus
        Assuming there is only a number (no whitespace) between the tags, the correct regex is
        (?-i)<Space_Tactical_Unit_Cap>\d+</Space_Tactical_Unit_Cap>
        and the Regular Expressions box in the find/replace dialog must be checked.
        The (?-i) at the beginning makes the regular expression case-sensitive, which is good practice when working with XML tags.
          PeterJones @Lupus
          @Lupus ,
          If you are in SEARCH MODE = Regular Expression, then the syntax you showed would probably have worked in certain cases. Or use .*? in the middle to make it less greedy. Or use \d+ in the middle to only allow integers (as @Mark-Olson said as I was typing).
          But you were basically there.
