    Not copy from clipboard by key Shift+Insert
    5 Posts 5 Posters 2.1k Views 2 Watching
    • Владимир БеспечныйВ Offline
      Владимир Беспечный
      Hi!
      In notepad++ version 8.6.1 64 bit? when I press key Shift+Insert text from clipboard not copy to notepad++, this key in other editors worked. Please help me, how to work key Shift+Insert as Ctrl-V
      tseGITT 1 Reply Last reply Reply Quote 1
      • tseGITT Offline
        tseGIT @Владимир Беспечный
        same problem in 8.6.1 32-bit. Also shift-delete does not work.
        Gone back to 8.6.0 32-bit. Shift-insert and shift-delete ars now working as again as expected.
        have seen later, there is a big discussion about this problem with in my opinion no solutin for me. so i stay with 8.6.0 for the next time.
        I’m using the NPPJSONViewer plugin a lot, so deactivating it is no solution for me.
        currently i’m using these plugins
        Plugins :
        ComparePlus (1.1)
        HTMLTag_unicode (1.4.1)
        MenuIcons (2.0.7)
        mimeTools (2.9)
        NppConverter (4.5)
        NPPJSONViewer (2.0.6)
        NppQrCode32 (0.0.0.2)
        XMLTools (3.1.1.13)
        _CustomizeToolbar (5.3)
        • Alan KilbornA Online
          Alan Kilborn @tseGIT
          @Владимир-Беспечный and @tseGIT
          Yes… no real workarounds and probably no extremely fast fix.
          Stay tuned.
          • Paolo LinxP Offline
            Paolo Linx
            Same problem.
            I tried to uninstall NPPJSONViewer plugin but nothing happened.
            Maybe some other plugin is interfering.
              Coises
              @Владимир-Беспечный
              @tseGIT
              @Paolo-Linx
              The workaround in 8.6.1 is given in this GitHub issue.
              This pull request indicates that the changes which caused this will probably be reverted in the next release.
