    Difference in display between Win11 Notepad and Notepad++
    3 Posts 2 Posters 3.5k Views 2 Watching
    • B Offline
      bartrpe
      Just for clarity, I’ve searched and found some new topics with similar keywords, but none of them looked legit. Others come from before 2018 so Win11 wasn’t even a thing back then.
      This is a file I have:
      md_01
      	playerModel	md_01
      	weapon		WP_BOT_LASER
      	reactions	3
      	aim			1
      	move		3
      	aggression	3
      	evasion		3
      	intelligence	5
      	playerTeam	TEAM_ENEMY
      	enemyTeam	TEAM_PLAYER
      	class		CLASS_REMOTE
      	yawSpeed	120
      	runSpeed	500
      	walkSpeed	150
      	height		32
      	width		8
      	hFOV		160
      	vfov		45
      	snd			remote
      	moveType	"flyswim"
      This is how it looks in Notepad on Windows 11:
      This is how it looks in Notepad++, newest version, Windows 11 too - here everything looks perfect, and this is where file was created:
      Where does this difference come from? As you can see, tabs on the line “aim” and “snd” are messed. How can I fix it? This happens to many other similar files. I want normal Windows Notepad to have tabs look normal. (my colleague uses just the normal Notepad, I use Notepad++).
        PeterJones @bartrpe
        @bartrpe
        Microsoft’s Notepad treats tabs differently than Notepad++ does. That’s why it looks different. The number of tab characters in the file is the same.
        In Notepad++, Settings > Preferences > Language contains the settings which influence how tabs are rendered. If your file is a .txt or other un-recognized file type (which it appears to be, since your screenshot shows no lexing), then use the [Default] entry for tab size. I am assuming Microsoft’s Notepad is just doing the old-fashioned 8-spaces-per-tab, whereas Notepad++ defaults to a Tab Size of 4. If you want Notepad++ to waste more screen space, then change that Tab Size to 8.
        And if you want to see how many tab characters are there in Notepad++, use View > Show Symbol > Show Space and Tab =>
        B 1 Reply Last reply Reply Quote 2
        • B Offline
          bartrpe @PeterJones
          @PeterJones Oh, so it’s actually a super simple issue. Thank you!
