    How to install and run a script in Python Script?
    24 Posts 3 Posters 26.6k Views 2 Watching
      PeterJones @dr ramaanand
      @dr-ramaanand said in How to install and run a script in Python Script?:
      I did all that was asked to be done in that FAQ. Now how to Renumber …
      The “USAGE” section in the FAQ explains how to run the script.
      dr ramaanandD 1 Reply Last reply Reply Quote 0
      • dr ramaanandD Offline
        dr ramaanand @PeterJones
        @PeterJones I did that and got this result:-
        I think I now got to go and remove the \ before the [ bracket from my file in the user script directory
        Is there a way to edit that or should I create a new script?
        Of course, the easiest way around this is to find <sup>\ and replace it with <sup>
        Unfortunately, I am unable to find <sup>\ in either the Normal mode or the Regular Expression mode
          PeterJones @PeterJones
          @dr-ramaanand ,
          Hopefully someone else will be able to help you. I’ve spent as much time on this as I can. Again, good luck.
          dr ramaanandD 1 Reply Last reply Reply Quote 1
            @PeterJones OK, thanks a lot! “<sup>.*?\[” finds what I want it to find, that is “<sup>\[” with the Regular expression mode turned on. I then put “<sup>[” in the Replace with field and hit “Replace all”
            • dr ramaanandD dr ramaanand referenced this topic on
