    Same action on the (same) highlighted sections
    10 Posts 5 Posters 1.4k Views 2 Watching
    • Gian MatteoG Offline
      Gian Matteo
      Hi fellows,
      I use the Highlighting feature without the “Match whole word” option.
      Iwould like to perform the same action on all the highlighted strings, let’s say click Del, or pressing a char to replace not only the original highlight but also all the remaing ones.
      I do remember having done this in the past, but maybe I’m wrong…
      P.S.: I posted the question because no help by googling, it is difficult to find the right keywords imo
      Thank you
        Alan Kilborn @Gian Matteo
        @Gian-Matteo said in Same action on the (same) highlighted sections:
        Sorry, no actions are currently possible on these strings of text, as the “Smart Highlighting” effect is only a visual one.
        Notepad++ has scripting plugins, which could make such a thing possible, but it can’t do it on its own.
        Gian MatteoG PeterJonesP 2 Replies Last reply Reply Quote 1
          Gian Matteo @Alan Kilborn
          @Alan-Kilborn thanks a lot friend, that’s so useful advice, at least I will stop loosing my time trying to remember how I… did(n’t) do it
            PeterJones @Alan Kilborn
            @Alan-Kilborn said in Same action on the (same) highlighted sections:
            Maybe I’ve misunderstood the original requirements. But if I’m right, after selecting one, which activates Smart Highlighting on the others, @Gian-Matteo should be able to use the new Edit > Multi-Select All > … family of actions to then multi-select all the words that were Smart Highlighted. Once they are multi-selected, then “click Del, or pressing a char to replace” will act on all of them, not just the first.
              Alan Kilborn @PeterJones
              @PeterJones said in Same action on the (same) highlighted sections:
              Multi-Select All
              Good call. I haven’t delved into the relatively new multi-editing capabilities, probably because of the potential conflicts with the age-old column block selection behavior.
                v8.6.4 with Multi-Select enabled and Column-to-Multi disabled behaves just like pre-8.6 with multi-select enabled, except it also has the new menu entries which allow extending the multi-selection easily; so it allows for reasonable column-select behavior while still allowing the new menu for multi-select: I’m quite happy with the current state. (The interim versions, on the other hand, where column-selects magically and unexpectedly became multi-selects were completely unusable for me.)
                CoisesC 1 Reply Last reply Reply Quote 2
                  Coises @PeterJones
                  … aside from the broken improved Ctrl+drag.
                    Alan Kilborn @Coises
                    @Coises said in Same action on the (same) highlighted sections:
                    aside from the … Ctrl+drag
                    If I’m not mistaken, that “simply” requires retraining yourself on proper key-lifting at the appropriate time. :-)
                    Or, is there more to it?
                    Andi KiisselA 1 Reply Last reply Reply Quote 0
                    • Andi KiisselA Offline
                      Andi Kiissel @Alan Kilborn
                      …requires retraining yourself on proper key-lifting at the appropriate time…
                      So Ctrl+Shift+… and Shift+Ctrl+… different behaviour would be acceptable too…
                      Sorry, not for me.
                        Alan Kilborn @Andi Kiissel
                        @Andi-Kiissel said in Same action on the (same) highlighted sections:
                        Sorry, not for me.
                        Sorry, don’t know what you mean.
