    Customization
    2 Posts 2 Posters 2.5k Views 2 Watching
    • pianoprofitonalP Offline
      pianoprofitonal
      Can i customize certain characters and letters?
      For example:
      Normal letters like “ABCD…e.t.c…” are a color
      special characters like:
      e.t.c…
      are a color and so on.
        PeterJones @pianoprofitonal
        @pianoprofitonal ,
        Create a User Defined Language (UDL) using Language > User Defined Language > Define Your Language, giving the language a name. On the Operators & Delimiters page, put the special characters (space-separated) into the Operators1 box, and use the Operators Styler button to assign the color for the special characters. On the Comment & Number page, use the Number Style’s Styler button to set the color for numbers. And on the Folder & Default page, Default Style, use the Styler button to set the “default” color, which will be the color of all the alphabetic (and unspecified) characters.
        Selecting that UDL from the Language menu (or defining the extension in the UDL, and opening a file with that special extension) will activate that special colorization.
