    Help with find and replace
    4 Posts 4 Posters 1.6k Views 1 Watching
    • Terri WillowkeepT Offline
      Terri Willowkeep
      I have a website that has changed file paths. I want to replace the …/directory to directory (note that they are different directories. All the directories however are now in the same folder as this file) So I put this : …/ in the find field and nothing in the replace field. Only instead of just replacing the …/ it deleted all my end tags!
      I don’t think I’ve ever had this issue before. Is this a bug or am I doing something wrong?
      This is the latest version of Notepad++
      Kim nahee 656K Alan KilbornA CoisesC 3 Replies Last reply Reply Quote 0
      • Kim nahee 656K Offline
        Kim nahee 656 Banned @Terri Willowkeep
          Alan Kilborn @Terri Willowkeep
          @Terri-Willowkeep
          I think you’d better show some actual data instead of just describing it like that.
          See HERE for some tips on how best to do this.
            Coises @Terri Willowkeep
            @Terri-Willowkeep said in Help with find and replace:
            My guess is that you have Search Mode: Regular expression selected when you mean to have one of the other two options. A period in a regular expression matches any single character.
