    Smart Highlight not working
    12 Posts 7 Posters 4.3k Views 2 Watching
    • Michael BelewM Offline
      Michael Belew
      I did search the forum and the web in general but I was not able to find a solution to my issue. I did try a couple things listed in other posts.
      I have used Notepad ++ for over 10 years and up until the last update I have had no issues.
      As of 8.7.1 My smart highlighting is not working.
      I checked Preferences > Highlighting - Highlight matching Tags and Smart Highlighting are enabled. I have disabled and re-enabled. I have changed multiple options in the Highlighting settings.
      Style Tokens do highlight the multiple instances of tags or words.
      I have uninstalled and reinstalled. When I uninstalled I removed all directories related to NPP (Install Folder and %APPDATA%\Roaming)
      I have changed from 32 bit to 64 bit. I originally stayed with 32 bit due to plug-in compatibility.
      Video with input overlay so you can see mouse clicks and double clicks. Grey bar across the top to hide personal information.
      https://drive.google.com/file/d/10avx-310JZet_L58weFm79Havt-hEsfE/view?usp=drivesdk
      same video different host
      https://youtu.be/FNJShIZfL_Y
      Any help would be appreciated.
      • Lycan ThropeL Offline
        Lycan Thrope @Michael Belew
        @Michael-Belew ,
        Best you post the picture or video here, as I don’t follow links posted by most people, and certainly not first posters. I don’t suspect many of us do as that invites bad actors to compromise our systems.
        If it can’t pass the forums checks, it won’t make it to be viewed here meaning I don’t want to follow it either.
        Michael BelewM EkopalypseE 2 Replies Last reply Reply Quote 0
          Michael Belew @Lycan Thrope
          @Lycan-Thrope
          You can also use a URL checker to check the safety of a link. Google has its own version of a URL checker called Google Transparency Report. To check the safety of a link, all you have to do is safely copy the link and paste it into Google’s URL checker. To safely copy a link, right-click and choose “copy link” from the options that appear. When copying the link, be careful to not click on it accidentally.
          Second the forum has no obvious way to post a video, only images. I provided 2 links to the same video, both Google owned sources, to try and make people more comfortable.
          I have converted the video to make it an animated GIF, but all of the converters online limit this length of video to 8 fps, which may make it difficult to see double clicks and other fidelity.
          Lycan ThropeL PeterJonesP 2 Replies Last reply Reply Quote 0
            @Michael-Belew ,
            Still seems like a lot of work just to see if it’s not hazardous without having to click it. Be that as it may, I think I see what you’re referring to. Can you post your debug information and maybe more knowledgable people will be able to help you? It seems I may have duplicated your issue myself. I used to think it was confusing when all those words were getting highlighted, but now I noticed my own version isn’t doing it anymore either, so I guess I have to add a me too, to this issue.
            Debug:
            Notepad++ v8.7.1   (64-bit)
            Build time : Oct 31 2024 - 00:48:56
            Command Line :
            Cloud Config : OFF
            Periodic Backup : ON
            OS Name : Windows 10 Home (64-bit)
            OS Version : 22H2
            OS Build : 19045.5131
            Current ANSI codepage : 1252
            Plugins :
                ComparePlus (1.2)
                CSVLint (0.4.6.7)
                CsvQuery (1.2.9)
                EnhanceAnyLexer (1.4)
                GitSCM (1.4.9.1)
                MarkdownViewerPlusPlus (0.8.2)
                NppConverter (4.6)
                NppExec (0.8.8)
                NppPluginDemo (4.4)
                NppSnippets (1.7.1)
                NppUISpy (1.2)
                PythonScript (2)
                TakeNotes (1.2.7)
                XMLTools (3.1.1.13)
              PeterJones @Michael Belew
              @Michael-Belew ,
              YouTube links are generally reasonable for people to click on (especially since the forum won’t let users obfuscate the real URL vs the apparent URL), though I would recommend using the full URL rather than the youtu.be shortened URL.
              On to your problem: I cannot tell for sure, because you haven’t posted the text for any data that replicates the problem for us to copy/paste into our Notepad++ instances, but my guess is that you have “must match whole word” in your options, and because of the quotes and equals and the specific data “words” that you are highlighting, it doesn’t match N++'s definition of “whole word”. If you had shared a screenshot of your Highlighting preferences, that would have been helpful; but for now, check those settings, and compare to the User Manual description (https://npp-user-manual.org/docs/preferences/#highlighting)
                Lycan Thrope @PeterJones
                @PeterJones ,
                Fair enough. :-) I know you meant @Michael-Belew , but I’m as guilty, too…so…
                Below is the screenshot and enough code to try for comparison.
                Here is a screenshot of the word (that you helped me with for the UDL) with selected along with the Highlighting preferences section showing. Only the one selected is highlighted, notice the ones underneath are not.
                Code:
                set procedure to containerobjects.cc additive
                ** END HEADER -- do not remove this line
                // Generated on 04/09/2023
                parameter bModal
                local f
                f = new PlainObjectListForm()
                if (bModal)
                   f.mdi = false // ensure not MDI
                   f.readModal()
                else
                   f.open()
                endif
                class PlainObjectListForm of FORM
                   with (this)
                      onOpen = class::FORM_ONOPEN
                      onClose = class::FORM_ONCLOSE
                      doubleBuffered = true
                      metric = 6	// Pixels
                      colorNormal = "Gray"
                      height = 529.0
                      left = 110.0
                      top = 29.0
                      width = 1092.0
                      sizeable = false
                      pageno = 1
                      refreshAlways = false
                   endwith
                   this.TESTCONTAINER = new CONTAINER(this)
                   with (this.TESTCONTAINER)
                      left = 114.0
                      top = 43.0
                      width = 885.0
                      height = 341.0
                      colorNormal = "0xfd563e"
                      borderStyle = 4	// Single
                   endwith
                   this.TESTCONTAINER.VSCROLLBAR1 = new SCROLLBAR(this.TESTCONTAINER)
                   with (this.TESTCONTAINER.VSCROLLBAR1)
                      onChange = class::VSCROLLBAR1_ONCHANGE
                      onLeftMouseDown = class::VSCROLLBAR1_ONLEFTMOUSEDOWN
                      height = 340.0
                      left = 864.0
                      top = 0.0
                      width = 20.0
                      value = 0
                      colorNormal = "0x5eb91a"
                      rangeMin = 0
                      rangeMax = 0
                   endwith
                   this.TESTBUTTON = new PUSHBUTTON(this)
                   with (this.TESTBUTTON)
                      onClick = class::TESTBUTTON_ONCLICK
                      height = 20.0
                      left = 344.0
                      top = 439.0
                      width = 104.0
                      text = "New"
                   endwith
                   this.TESTDELETEPB = new PUSHBUTTON(this)
                   with (this.TESTDELETEPB)
                      onClick = class::TESTDELETEPB_ONCLICK
                      height = 20.0
                      left = 599.0
                      top = 439.0
                      width = 108.0
                      text = "Delete"
                   endwith
                   this.OBJCOUNT_SB = new SPINBOX(this)
                   with (this.OBJCOUNT_SB)
                      height = 22.0
                      left = 171.0
                      top = 439.0
                      width = 56.0
                      picture = "999 "
                      function = "I"
                      rangeMax = 100
                      rangeMin = 1
                      value = 0
                      spinOnly = true
                   endwith
                   this.OBJCOUNT_TL = new TEXTLABEL(this)
                   with (this.OBJCOUNT_TL)
                      height = 22.0
                      left = 59.0
                      top = 439.0
                      width = 91.0
                      text = "Object Count:"
                      colorNormal = "Black/Gray"
                      fontBold = true
                   endwith
                   this.OBJSEL_SB = new SPINBOX(this)
                   with (this.OBJSEL_SB)
                      height = 22.0
                      left = 171.0
                      top = 471.0
                      width = 56.0
                      picture = "999 "
                      function = "I"
                      rangeMax = 100
                      rangeMin = 1
                      value = 0
                      spinOnly = true
                   endwith
                   this.OBJSEL_TL = new TEXTLABEL(this)
                   with (this.OBJSEL_TL)
                      height = 22.0
                      left = 59.0
                      top = 471.0
                      width = 109.0
                      text = "Object Selected:"
                      fontBold = true
                   endwith
                endclass
                  Hello, @michael-belew, @lycan-thrope, @peterjones and All,
                  @lycan-thrope, I don’t really understand what you want to explain to the OP !
                  To my mind, in order to see the global behaviour of the Smart Highlighting feature, just use this simple text, below, that you’ll paste in a new tab :
                  This is a test
                  This is a Test
                  This is a TEST
                  This is a teST
                  This was tested yerterday
                  This was Tested yerterday
                  This was TESTED yerterday
                  This was teSTed yerterday
                  This idea is detested
                  This idea is Detested
                  This idea is DETESTED
                  This idea is deteSTed
                  An another test to do
                  An another Test to do
                  An another TEST to do
                  An another teST to do
                  This was tested yesterday
                  This was Tested yesterday
                  This was TESTED yesterday
                  This was teSTed yesterday
                  Then :
                  • Open the Settings > Preferences... > Highlighting section
                  • Enable the Smart Highlighting feature
                  • Double-click on the word teST of the fourth line of my text
                  • Now, check / uncheck the Match case and/(x)or the Match whole word only option(s)
                  Quite easy to understand, isn’t it !
                    Alan Kilborn @Lycan Thrope
                    @Lycan-Thrope
                    I don’t have any problem (using 8.7.1) with Smart Highlighting and your example:
                    MarkusBodenseeM 1 Reply Last reply Reply Quote 0
                    • MarkusBodenseeM Offline
                      MarkusBodensee @Alan Kilborn
                      @Alan-Kilborn said in Smart Highlight not working:
                      Same for me, works as expected. Maybe a problem in relation with the UDL or a plugin?
                      Here is my Debug info:
                      Path :
                      Command Line :
                      Local Conf mode : ON
                      Cloud Config : OFF
                      Periodic Backup : OFF
                      OS Version : 22H2
                      Plugins :
                          ComparePlus (1.2)
                          DSpellCheck (1.5)
                          HexEditor (0.9.12)
                          NppConverter (4.6)
                        Ekopalypse @Lycan Thrope
                        @Michael-Belew
                        perhaps your theme has set the background color of the smart highlighting to match the default background color?
                        Lycan ThropeL Michael BelewM 2 Replies Last reply Reply Quote 3
                          Lycan Thrope @Ekopalypse
                          @Ekopalypse ,
                          Bingo, we have a winner. I have no idea why that color was selected as the same background, or…it was by default and then when I changed my background color to what it is now, the conflict occurred. I never noticed it, but I’ve changed it to a cyan, and it does show up now.
                          Thanks for that catch.
                          Thanks to all for their suggestions, and maybe the OP can now check his settings to solve his problem.
                          OP, might have the same problem. If you notice, the first with has different coloring than the others, I suspect the result of the current selection color choice being melded with the SmartHighlighting background color.
                            Michael Belew @Ekopalypse
                            @Ekopalypse I know this is very old post, I have just lived with it till now. I started to try and find the answer again and found my own old post. You are correct the background for the Global Style Smart Highlighting was set to the default background. This fixed my issue.
