    Using Makefile syntax highlighting as a base for Justfile UDL?
    2 Posts 2 Posters 612 Views 1 Watching
    • Ky WaegelK Offline
      Ky Waegel
      I’d like to create a user-defined language for Justfiles, since I can’t seem to find any existing one to use. The syntax is very similar to makefiles, so is there any way to use the built-in makefile highlighting as a starting point, or do I need to create the entire UDL from scratch?
        Terry R @Ky Waegel
        @Ky-Waegel
        I don’t use any of these functions (currently), however a quick search of the forum came up with this post by one of our more experienced users. Have a read of this post. I think it might answer some of your questions (hopefully).
