    My first plugin development: CollectionInterface [was: Need help with getting started using C++ Plugin Template]
    68 Posts 8 Posters 47.4k Views 2 Watching
    • Lycan ThropeL Offline
      Lycan Thrope @PeterJones
      @PeterJones said in Need help with getting started using C++ Plugin Template:
      [*] update: yes, AC files must match the “display-name” (ie, the <UserLang name=“XYZPDQ” … name); I need to update the CONTRIBUTING.md to make that clear, and eventually update the automatic checks run on the repo so that any AC filename must match its associated UDL actual-name. Yay, another thing for my growing TODO list on this project. ;-)
      Now you know how I felt making the UDL. I had to figure out how to implement the features everyone wanted, via the Notepad++ features and learn how to do it, then learn the hard way that the naming matters, and then write the installer because people had problems figuring out which dbaseplus.xml (UDL, functionList & autoCompletion) file went into which directory, then try and explain how to modify the overrideMap.xml file, and then depending on if they had a standard, portable and/or cloud install, and then write the installer to handle it all. I know your angst, believe me. :-)
      And your herculean efforts are appreciated for sure by me for my future works, considering you can’t time travel. :-) So Thanks!
        Lycan Thrope @Coises
        @Coises ,
        I can understand your point about upon having a popup appear when the user tries closing the dialog box, alerting them that their changes won’t take effect until NPP is rebooted, so you’re putting the responsibility on to the user…which by the way, is counter to the way the Plugin Admin itself does things.
        It does the reboot, the same as @PeterJones plugin does, which is what I would expect when I’m required to reboot after completion, also just like Windows own update process requires. This might be the only change needed for the reboot procedure, but other than that, for a rough first version, it’s fine for me…I read directions. Sometimes not as well as I should, but I do read them. :-)
          Coises @PeterJones
          @Coises,
          since you’re using an asynchronous interface (wininet) you should be able to put a cancel button on the downloading dialog. (Progress would be more work; I’d guess these files are small enough that it wouldn’t be necessary?)
          With the downloading happening self-contained in a method on the object, rather than being inside the dialog-handler, I’m not sure of an easy way to signal the class/method to stop the download. Progress, in my mind, would be easier, because if I just passed the control for the progress bar as an argument to the download method, it could send the right signals at appropriate times. But we’ll see what I can figure out.
          My apologies. I also used wininet, but forgot that asynchronous operation is an option, not the only way it works. I see from your code that you are operating synchronously. I think passing a progress bar control couldn’t work, because if you’re operating synchronously, the message loop doesn’t run until you return. You can update the control, but the change won’t be displayed because the message loop never gets control to update the display.
            Next GUI opinion: if I’m going to make the “download AutoCompletion/FunctionList at same time as UDL” optional, I’ll want checkboxes.
            Should they go on the left or right?
            My plan is to disable the checkbox for a given UDL if the UDL doesn’t have the corresponding AC or FL. And on the AC, FL, and Theme tabs, the checkboxes will be hidden completely (but the Download button will still be in the same place).
            CoisesC Lycan ThropeL 2 Replies Last reply Reply Quote 3
              Coises @PeterJones
              I think left is better.
              PeterJonesP 1 Reply Last reply Reply Quote 4
                PeterJones @Coises
                @Coises ,
                Thanks, I was thinking that, too.
                The copy currently in GitHub now allows the additional download of the associated AC or FL for a given UDL. (But it still only allows selecting one UDL at a time.)
                Whether in the AlsoXX mode or the normal XX category, it also now warns you if it’s going to be asking for elevated UAC permissions (usually when downloading AutoCompletion, since those go in Program Files), and if you CANCEL, it will not bother with the UAC prompt and thus won’t download the file. I thought that people might be confused why Windows was giving the UAC elevation prompt, so decided that a MessageBox in between would be helpful.
                  @PeterJones ,
                  Left for me too, although, when I first looked at it, I thought you were doing a selection on the left and the right would expand showing the files that the UDL could download…and then those would have checkboxes…but then I saw the red line and realized while reading it was an either or choice. :-)
                  As for the UAC mention a little further down, are you able to do that via NPP and the installation? I know NPP does it, so that’s why I ask…in my installer, I had to let people know they might have to install the package while in Admin mode, for the autoCompletion file for a standard install.
                    PeterJones @Lycan Thrope
                    @Lycan-Thrope said in Need help with getting started using C++ Plugin Template:
                    Sorry, at one point, I thought I put in a “VS” next to the red line, but I did an UNDO on that at some point while manipulating the image. I probably should have just pasted two separate images, rather than joining them to one.
                    https://github.com/pryrt/NppPlugin-CollectionInterface/blob/dfbaff5596c7e905747dde0f164243b6cc08e98b/src/Dialogs/CollectionInterfaceDialog.cpp#L249-L260
                    Since neither Notepad++ nor my plugin have Elevated permission yet, and I didn’t want to tell the user that they had to restart Notepad++, I cheat: instead of downloading the file directly to the protected directory, I download it to a temporary directory (and hence the GetTempPath2W-vs-GetTempPathW from earlier), then I run a ShellExecute runas to copy from the temp-dir – and the runas prompts for the UAC for just the process that’s copying the file.
                    Lycan ThropeL 1 Reply Last reply Reply Quote 3
                      @PeterJones ,
                      Clever. :-)
                      Now, you might be interested to know, that your package download works just fine, as far as getting the files in the right directories. However, this brings up the file naming (internally and externally) problems that I was mentioning earlier.
                      Since the dBASEPlus UDL is currently the only UDL package with all 3 files, (sans additional separate themes other than Dark and Light variants), I had to rename things, and I think I got it sorted out and wasn’t sure if this is something you are going to work on, or was going to leave for later. I know the filenames in the JSON in the repository are probably what will need to be changed, but have some info about what the final product for all 3 packages needs to look like.
                      1.) The UDL userDefineLangs name needs to be the same internally and externally and in the same case for the functionList definition to work properly and that name needs to be in the overrideMap.xml in the same case. (any change in case in any of the 3 places, makes the functionList not function)
                      2.) The name of the autoCompletion files can be any case, as long as the name is the same as the actual UDL’s file name. (which should have internal/external the same, and case wise)
                      eg. dbaseplus_light.xml to be used for autocompletion of the dBASEPlus_Light.xml UDL.
                      3.) The actual functionList file can be the same file for both Dark and Light versions, just the overrideMap.xml file has to point the association to each like so:
                      <association id= "dbaseplus.xml"		userDefinedLangName="dBASEPlus_Light"/>
                      <association id= "dbaseplus.xml"		userDefinedLangName="dBASEPlus_Dark"/>
                      Any future dBASE variants would be named differently to accomodate that version’s functionList needs, for both Light and Dark. Such as dbaseIIIPlus.xml, dbase4,xml, etc.)
                      My original naming was helped by your putting the name first and the color type after, but the extremely long name, or only changing the internal name differently than the external name, causes linkage problems between the 3 different aspects. I think you already know that, but thought it was probably something that I should bring up that is the only hiccup right now.
                      I hope this helps rather than complicates your current development focus. :-)
                        @Lycan-Thrope ,
                        I don’t quite agree with your interpretation:
                        1. UDL Naming Mismatch OK: I created a UDL file called GeoRge.xml with <UserLang name="Gracie"
                          It is recognized as a UDL, and the mismatch between the filename and the internal name doesn’t interfere with UDL or FunctionList or AutoCompletion, as long as FunctionList and AutoCompletion reference the internal Gracie, not the GeoRge.xml filename.
                        2. FunctionList Filename/displayName mismatch OK:
                          Example: With FunctionList filename GracieFL.xml and the setting inside GracieFL.xml being <parser displayName="ThisIsIgnored", and the overrideMap.xml having the line:
                          		<association id= "graciefl.xml"			userDefinedLangName="Gracie"/>
                          it all maps correctly.
                        • The association ID name must match the FL filename, but case is not important, because the Windows filesystem is not case sensitive.
                        • The association userDefinedLangName must match the <UserLang name="...", but doesn’t care about the UDL definition’s filename
                          • I can, however, confirm that if userDefinedLangName="gracie" case does not match <UserLang name="Gracie" case, it will not map properly, because XML attribute values are case-sensitive, and Notepad++ does the internal searching based on case.
                        • Notepad++ ignores the FL parser’s displayName and id values for any of these mappings.
                        In my example, the regex is <function mainExpr="(?x-is)^\d+\..*(?=:)"/> so that the dummy text as I am writing up this post will have functions, so I can share screenshot showing that with these settings, it does correctly show FunctionList
                        1. AutoCompletion needs to match UDL name, not filename:
                        If I name the AutoCompletion file gracie.xml – so it matches the <UserLang name="Gracie" (case insensitive), but does not match GeoRge.xml, the autoCompletions work properly.
                        However, other than the fact that I can enforce AutoCompletion filename name must match the UDL’s internal name (with the .xml extension added), none of this has to do with my plugin.
                        Lycan ThropeL 2 Replies Last reply Reply Quote 0
                          LSL_byKimpaTammas (“LSL”) has UDL and FunctionList and AutoCompletion
                          But they have the same problem, where the autoCompletion filename matches the UDL filename LSL_byKimpaTammas.xml instead of the UDL’s internal name, which is just LSL.
                          I have not yet had an opportunity to improve the consistency-checks (validators) in the UDL repo yet, though the issue #303 exists.
                            @PeterJones ,
                            I stand corrected. I didn’t scroll the longer list, so missed it. Doh!
                              @PeterJones ,
                              This is wierd, because I spent the earlier part of the day, testing just for these different scenarios, changing something, saving, closing NPP, and then reopening. I would open a recent file and if the FL didn’t populate I worked the different aspects and that’s what made me document the changes of names and how they needed to be.
                              Hmm…can’t explain that…and this is the repaired NPP exe that changes to the correct UDL/FL combination that was fixed from my bug report.
                              Hmm…I think I need to go retest this and find out what went changed, because I thought I was being pretty meticulous with these checks. Remember, I have Dark and Light versions, and that’s how I was knowing when one was working and the other wasn’t.
                                @PeterJones ,
                                Well, I don’t know how it happened, but either through a fluke or what not, all that testing I did was just undone.
                                It took a while to get it right with your naming the file one thing and the internal name another, but I ended up getting it to work like you show. I just can’t explain how it didn’t work that way the first time I went through it…but oh well. :-(
                                  I have a version good enough that I’m going to call it “beta”:
                                  https://github.com/pryrt/NppPlugin-CollectionInterface/releases/tag/v1.0.0beta
                                  It doesn’t have multiple-UDL-download feature (that can wait until a future version), but it’s got the download one file, or download UDL+FL/AC. It should properly ask for UAC permission on AutoCompletion. It will ask if you want to restart Notepad++ through a new MessageBox after the Done button is pressed on the main dialog. There is a ? button on the dialog, and that help is also available through the plugin’s menu.
                                  Mostly what I’m looking for at this point is feedback on whether it does what I claim it does, and whether it works as expected for other people, not just for me. For now, ignore any problems with the metadata mismatch that @Lycan-Thrope has been focused on; I will eventually improve the UDL Collection checkers to flag those, and work on fixes. Other than that, let me know if you think there are any show-stoppers that would prevent it from being released.
                                  (I’m calling this beta, not RC, because I know there are at least one-or-two behind-the-scenes things that I want to improve, though hopefully the end user wouldn’t be able to guess what those might be, because it shouldn’t affect the user.)
                                  Lycan ThropeL 2 Replies Last reply Reply Quote 2
                                    @PeterJones ,
                                    It worked flawlessly, and I even downloaded a theme to test that. (I hadn’t before, sorry).
                                    I also just submitted a pull request to fix wording in the Help Dialog, mostly to see if I did my local branch fix properly, recompiled…and then submitted a pull request with the fix. Baby steps, and hopefully nothing blew up with my fledgling GitHub skills.
                                    Update: I’ve mainly been testing the package download, but I can go back and test the individual downloads as well, now.
                                      @PeterJones ,
                                      Houston, we have a problem. :-)
                                      I was trying to check other files with the FL and AC, and tried doing just the UDL and then the same UDL w/AC&FL…they worked with what appears to be one exception. Vim by @rdipardo .
                                      At first I thought it was a limitation in size of the UDL list, but apparently even after deleting some languages, it still wouldn’t appear. So I checked the UDL file which did download into the right directory, and it appears that it’s not a standard UDL file. All the files downloaded into the correct directories, but it’s not showing in the list, and I have to attribute that to the fact that it looks like it’s an HTML file, rather than an XML file.
                                      Just an FYI.
                                      PeterJonesP rdipardoR 2 Replies Last reply Reply Quote 0
                                        @Lycan-Thrope ,
                                        apparently, when @rdipardo submitted to the collection, the JSON was set to point to the HTML wrapper for the gist. So it’s a data problem (which the validator should have caught) in the repo, not a problem with the plugin.
                                          @PeterJones ,
                                          Yeah I kind of figured that, but was just relaying the find, even though it isn’t the plugin’s fault.
                                          I know you have the list check the repository, rather than checking the user’s to see if they already have it, and then it dawned on me, that they might need to redownload an uncorrupted version if they screwed something up…although I’d have deleted it first before downloading again, I wonder if it’s worth it to add that check to see if they really want to redownload it. No harm no foul if it actually downloads overwriting a bad one, but if they made changes, they wanted to keep, then it might be a problem…but it’s their problem for not backing it up. :-)
                                          • rdipardoR Offline
                                            rdipardo @Lycan Thrope
                                            If I understand correctly, wouldn’t the same thing happen with any UDL whose repository field is not a static XML resource?
                                            If that’s the case, a few more entries appear to need fixing:
                                            $ curl -sSL https://raw.githubusercontent.com/notepad-plus-plus/userDefinedLanguages/refs/heads/master/udl-list.json |\
                                              jq -MCr '
                                                .UDLs[]
                                                | select(.repository | length > 0 and (test("((^https?://raw)|\\.xml$)") | not))
                                                | ."id-name"'
                                            AgenaUDL
                                            AMXX_1.8.3_OciXCrom
                                            AsteriskExtensionLanguage-AEL_by-eyzel
                                            AuditCommandLanguage-ACL_byJChen
                                            Fortinet_FortiOS_FGT_by_SSavaso_6_4_14
                                            GPD.byRajendraSingh
                                            jai.udl
                                            jQuery_byJamesAllardice
                                            Klipper-GCODE-Dark-by-Iron3eagle
                                            Liquid_dark_byFabbroDan
                                            markdown-plus-plus
                                            MSC-Nastran_by-onurarifyasa
                                            MSC-Patran_by-onurarifyasa
                                            Objective-C++_byLattHsiang
                                            PowerBuilder_DM_byFa0lin
                                            Smali_byJasi2169
                                            TinyFugue_byYrwin
                                            Vimscript_Obsidian_by_rdipardo
                                            zenscript
