    Need help with RegEx
    3 Posts 2 Posters 777 Views 2 Watching
    • Smudge the catS Offline
      Smudge the cat
      Hi, everyone. I need help on how I can search for message if it includes more than X characters in total.
      For example: I want to search a username, let’s say “Smudge”. There are characters before Smudge and I do not want them to be included so I’ll be typing “Smudge.*”. But how can I make this so it only shows results if there are X or more characters coming after the username Smudge?
      Thank you!!
        PeterJones @Smudge the cat
        @Smudge-the-cat ,
        See the User Manual > Searching > Regular Expressions > Multiplying Operators for all the details on how to set quantities.
        You will want Smudge.{X,} where X is whatever number you want, and the comma is needed to say “or more”.
        Smudge the catS 1 Reply Last reply Reply Quote 2
          Smudge the cat @PeterJones
          @PeterJones thank you so much for the help!!
