    When is there going to be a release of NPP plugintemplate with a definition of NPPM_ADDSCNMODIFIEDFLAGS
    13 Posts 4 Posters 3.8k Views 2 Watching
    • ThosRTannerT Offline
      ThosRTanner
      There hasn’t been a release of the template for about a year, and it doesn’t have a definition of NPPM_ADDSCNMODIFIEDFLAGS so I have to add one myself if I want to use it.
      Could we have an update pretty please?
      CoisesC PeterJonesP 2 Replies Last reply Reply Quote 0
      • CoisesC Online
        Coises @ThosRTanner
        @ThosRTanner said in When is there going to be a release of NPP plugintemplate with a definition of NPPM_ADDSCNMODIFIEDFLAGS:
        Of course, the way to request that would be to raise an issue in the plugintempate repository.
        This made me think, though (regarding both plugintemplate and plugindemo)…
        1. Several files should always be up-to-date with the latest release of Notepad++. One would think there might be a way to do that automatically in GitHub.
        2. It might make sense to instruct people to download from master rather than the latest “release”; then making a new release wouldn’t be a requirement every time a file is updated to match Notepad++.
        3. It seems like these repositories should be a GitHub template repositories.
        I don’t know GitHub well enough to know how to automate point 1 above (or if it is possible), or if there are reasons not to do 2 or 3.
        In the meantime, it’s probably a good idea to update all the files that come from Notepad++ before starting a new project based on any template.
          PeterJones @ThosRTanner
          @ThosRTanner ,
          All you have to do is download the most recent Notepad_plus_msgs.h overtop the one in the template – and for Scintilla messages, get the most recent Scintilla.h as well. But I understand that having it pre-packaged in the template would be nice.
          Who do you think you’re talking to, here? You’ve been here long enough to know that Don doesn’t read the most of the posts in the forum, except for in reply to his Announcements or his other rare posts: if you want to request an update to the template, creating an issue in the plugintemplate repo is the way to get his attention to get a release: just poking us fellow Notpead++ users will not help with that.
          ThosRTannerT 1 Reply Last reply Reply Quote 1
            PeterJones @Coises
            The way that immediately comes to mind would be to have a time-based GH Action in the template repo that once a month downloads the most-recent copy of Notepad_plus_msgs.h and Scintilla.h and (if there’s a change) then the action can commit it back into the plugintemplate repo. I could probably develop that GH Action, if someone else had made an Issue requesting that it get auto-updated (hint, hint, @Coises).
            There’s probably some more git-centric (rather than GitHub Action) way of doing that, too, but I’m not enough of a git expert for that.
            1. It seems like these repositories should be a GitHub template repositories.
            That’s something to suggest in a separate Issue, making sure to put a link to those instructions in the request, so that Don knows how easy it is to turn it into a template. (The README could also be updated to include a summary of the instructions here for how to use a template repo to create a new repo based on that template.
            The one thing I see is that if both 1 and 3 are implemented, then the GHAction from 1 would be included when someone used the template-repo to create a new repo. It would be, in a way, “nice”, because it would make sure your plugin kept up-to-date; but it would also make changes to your plugin without your control, so it could be considered “bad”.
            CoisesC 2 Replies Last reply Reply Quote 2
            • CoisesC Online
              Coises @PeterJones
              @PeterJones said in When is there going to be a release of NPP plugintemplate with a definition of NPPM_ADDSCNMODIFIEDFLAGS:
              I think (but again, my understanding of both git and GitHub are very elementary) that when a template repository is used as the source of a new repository, there is no persistent connection between the two. The template just initializes the new repository with structure and files.
              No one would (or should, anyway) fork the plugintemplate or plugindemo repositories. Having it be a template would just — again, if I understand it correctly — make it possible to start by making a new repository for your plugin on GitHub and then sync your local MSVC/git to that, if you preferred that to downloading the project, opening it in MSVC and then pushing it to git later.
                PeterJones @Coises
                I had never heard of the “template repo” feature until you linked it. But from my reading, when you create a repo based on that, it copies the entire structure of that repo – not as a link, but the whole structure; the GitHub Action Workflow definitions would seem to me to be part of that structure, so I would assume they would be copied; and thus, the action would still be there and active. (Again, if I understand correctly)
                If I understood the second page (the one I linked), it’s not a fork. But the creation process copies everything, including workflows
                • CoisesC Online
                  Coises @PeterJones
                  Issue #13: “Feature” request: Update files from Notepad++ automatically created.
                  • CoisesC Online
                    Coises @PeterJones
                    Ugh. I missed that. You’re probably right, and that would be bad.
                    I know nothing yet about creating actions. Would it be possible to create the action so that it only runs if it is running in “nppplugins/plugintemplate” and would otherwise do nothing (unless the creator of the new repository changed it)?
                      PeterJones @Coises
                      Actually, I think you can; I think I have an example in one of the other actions I deal with… I’ll look into that and confirm as I work on #13.
                      rdipardoR 1 Reply Last reply Reply Quote 0
                      • rdipardoR Offline
                        rdipardo @PeterJones
                        Actually, I think you can.
                        An outline of such a workflow would be:
                        • Run the build on the schedule trigger event, as already suggested in the issue thread, e.g.:
                        on:
                          schedule:
                            - cron: "0 0 1 * *" #< first day of every month at 00:00 UTC
                        • Use the checkout Action to fetch the Notepad++ trunk
                        • Use a diffing tool or action to compare the file paths of interest. If something changed, copy the upstream files into the template’s file paths and feed the project to MSBuild
                        • If the build passes, push the changed files and create a release
                        ThosRTannerT 1 Reply Last reply Reply Quote 2
                          ThosRTanner @rdipardo
                          @rdipardo Wouldn’t a better place to put the action be in the notepad++ repo so when a new version was released it’d do the updates to the template repo automatically?
                          @PeterJones @Coises thanks for all the replies and though processes on this.
                          rdipardoR 1 Reply Last reply Reply Quote 1
                            ThosRTanner @PeterJones
                            @PeterJones you’d be surprised how much I don’t know despite having hung around for a long time
                            • rdipardoR Offline
                              rdipardo @ThosRTanner
                              You make a good point.
                              The workflow steps would essentially be the same, but in the opposite direction (clone the template repo, update the file tree, validate the build and push if successful). The main difference would be the trigger; ideally you would want to watch for tagged Notepad++ releases, e.g.,
                              on:
                                push:
                                  tags:
                                    - 'v*'
                              This way new template versions can be explicitly tied to a Notepad++ release, e.g.,
                              # 'refs/tags/vX.Y.Z' -> 'vX.Y.Z'
                              echo "NPP_RELEASE=${env:GITHUB_REF}.Split('/')[2]" >> $env:GITHUB_ENV
                              git tag -a "${{ env.NPP_RELEASE }}" '@' -m "plugintemplate-for-Npp-${{ env.NPP_RELEASE}}"
                              git push --tags --repo=https://github.com/npp-plugins/plugintemplate
                              But it would be a problem if incompatible changes were made to the template. A failed build would cause a red X to appear beside the tagged Notepad++ commit, giving the false impression the release was a botch.
                              I think the separation of concerns principle is best observed if the template project looks after its own updates. A little extra churn won’t be a great inconvenience. The majority of plugin authors are still copy-pasting the template files into their source tree, as shown by how many have “C” as their detected primary language, since the template files contain no unique C++ syntax or standard headers, which GitHub relies on to classify header files, unless you manually override the heuristics.
